![]() Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) ![]() |
my dumb ass hit a curb the other night, but there is no noticable vibration under 60mph. on highway speeds, however, the car shakes pretty bad, and the steering wheel vibrates even worse. although i didnt look too closely, there doesnt seem to be and visible dents to my rim(s) on the passenger side. is there anything i can do myself or anything an auto shop can do for relatively cheap that will fix the problem. im guessing its just a very slightly bent rim.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
Jack up your car and by hand rotate the wheels. If it isn't straight you got a dented rim. My car was like that when I bought it too. Even tho the rims look ok, they aren't!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(soulshadow @ Oct 24, 2005 - 4:40 AM) Jack up your car and by hand rotate the wheels. If it isn't straight you got a dented rim. My car was like that when I bought it too. Even tho the rims look ok, they aren't! [right][snapback]348290[/snapback][/right] Wouldn't he have to rotate the wheels fast enough to simulate the amount of rotations one would normally get in 3rd gear at 60 mph? ![]() But I agree, you don't have to be able to SEE anything for the rim to be dented, which is exactly what it sounds like |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) ![]() |
Could be your control arm(I think that what it called)?
Best to bring it in to a wheel place so they can look at it. Edit: Could it also be that your alignment is out? which will cause the steering wheel to vibrate? I'm just throwing ideas out. So dont shoot me... This post has been edited by CelicaZR: Oct 24, 2005 - 7:43 AM -------------------- ![]() 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
QUOTE(CelicaZR @ Oct 24, 2005 - 3:28 AM) Could be your control arm(I think that what it called)? Best to bring it in to a wheel place so they can look at it. Edit: Could it also be that your alignment is out? which will cause the steering wheel to vibrate? I'm just throwing ideas out. So dont shoot me... [right][snapback]348326[/snapback][/right] he is right. Also the tire could just need a balance. -------------------- |
thanks, ill just have a shop look at it asap.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
if you bent your suspension arm #2, if got a spare.
well the verdict is that the front right rim is slightly bent and the rear right rim is very slightly bent. are there any common shops that can repair wheels? if not, what is the cheapest/best online place? thanks ahead for any input.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) ![]() |
There is a place in Kansas City that will straighten your bent rims (to a point without busting them). I'd call around to different wheel shops, see if they do repairs.
Enthusiast Joined Jul 29, '04 From Maryland Currently Offline Reputation: 0 (0%) ![]() |
Or it could be that the bearing got tore up a little from the jolt. Happened to my dumbass too, had to replace the hub and bearing and wheel., but it is fine now.
how much was the bearing and hub, and how hard was it to replace?
Well, i had a dealership do it so i got screwed over mostly.
But, the hub and bearing are around 150-200 bucks. and install was like 400. Its a bit of work unfortunately, because the hub is pressed into the bearing, and then that is pressed into the watcha call it thing, unfortunately i forget. But after i took my car into a curb, the wheel would wobble at just about any low speed, and i didn't dare take it to a high speed. |
toyota quoted me 320 for the hub and bearing and that was at cost. i got a used one from coomer for 75 and put it on myself. its not that hard if you have air tools.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) ![]() |
u know what's insane? i recently hit a curb too & my caster is WAY off on the left side...hope nothing is BeNT! anyways-that would really suck but now there is NO VIBRATION anymore!! isn't that the oddest crap ever?
i still have to take her to get checked out... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
Could be that you broke off one of the little weights that balence the wheel, that would case it to shake only at higher speeds, I would check that before anything else.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 20, '03 From Annapolis, Md Currently Offline Reputation: 5 (100%) ![]() |
I finaly got my car fixed again. Had the wheel baring replace,d said the hub was fine.It drives much better and smoother, but a lil pooping around hard turns.. Im sick of cars.. Cause I nor three other mechanics can figure it out.. but I just might be going crazy.
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) ![]() |
QUOTE I finaly got my car fixed again. Had the wheel baring replace,d said the hub was fine.It drives much better and smoother, but a lil pooping around hard turns.. Haha. Maybe bring an extra pair of pants with you? -------------------- ![]() A Jaws4God Creation... |
Lo-Fi Version | Time is now: February 25th, 2025 - 1:45 PM |
