2 Pages V  < 1 2
> V-6 Camry axle and alltrac axles are different
post Nov 1, 2005 - 8:24 AM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I'll have to look at what year camry axle I had, I think is was 1993.
post Nov 1, 2005 - 8:43 AM
QUOTE(scothaniel @ Oct 31, 2005 - 5:30 PM)
I have a non-lsd and lsd passenger side MR2 inner axles, they look identical. Are you sure its in all the way? Does the bearing carrier line up?
Scott
90 All-Trac +
96 Celica +
Michigan
[right][snapback]351084[/snapback][/right]
I have a 93+ TRD tranny and they changed I believe the passenger side inner hub. The splines are a bit shorter.
post Nov 1, 2005 - 12:10 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
QUOTE(scothaniel @ Oct 31, 2005 - 11:55 AM)
It depends on which year / model Camry outer axle your talking about. I think we need to be more descriptive when talikng about them.
[right][snapback]351036[/snapback][/right]
This is what I have.
'93 3s
'91 MR2 T Trrany
'91 MR2 T Inner axel shafts
'91 Camry V6 Outer axel Shafts.
'94 6gc hub
Everything seems to be working fine.
QUOTE(Supersprynt @ Oct 31, 2005 - 12:22 PM)
Sphinx you dont have the LSD tranny right? Mine makes noise taking corners I've heard this is a normal noise but still, cant help but be concerned.
[right][snapback]351049[/snapback][/right]
No, mine isn't LSD. And I don't think it's normal. What kind of noise is it? Can you describe it?
This post has been edited by sphinx: Nov 1, 2005 - 12:11 PM
post Nov 1, 2005 - 12:13 PM
It could be a lack of oil due to this leak, it could be something totally unrelated to the transmission right now the exhaust leak is so loud I cant get a good listen as its not that loud. I'm most certain I have the wrong inner passenger-side inner axle hub so when I get a 93+ inner i'll put that in and then try to diagnose this sound. It could simply be that the axle isnt actually in all the way, and has movement.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 11th, 2024 - 6:03 PM
