FS: Headlights |
FS: Headlights |
Oct 23, 2005 - 9:27 PM |
Enthusiast Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) |
Hey everyone I found some headlights on ebay.
link1 Item # 8008337316 link2 Item # 8008281600 link3 Item # 8009673625 link4 Item # 8009662330 This post has been edited by dustin15brown: Oct 23, 2005 - 9:33 PM -------------------- |
Oct 23, 2005 - 10:04 PM |
Enthusiast Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
so? they are even JDM
-------------------- <<AKA THA RUSSIAN>>
Oct 23, 2005 - 10:17 PM |
QUOTE(Niskyspy @ Oct 24, 2005 - 3:04 AM) so? they are even JDM [right][snapback]348216[/snapback][/right] JDM and US OEM are the same.... they may be JDM, but you cannot tell. A lot of times JDM is a key word used for search only. The only JDM lights that are different are the clear high beams and projector low beams -------------------- |
Oct 24, 2005 - 10:00 AM |
QUOTE(dustin15brown @ Oct 23, 2005 - 11:17 PM) QUOTE(Niskyspy @ Oct 24, 2005 - 3:04 AM) so? they are even JDM [right][snapback]348216[/snapback][/right] JDM and US OEM are the same.... they may be JDM, but you cannot tell. A lot of times JDM is a key word used for search only. The only JDM lights that are different are the clear high beams and projector low beams [right][snapback]348226[/snapback][/right] not true. JDM headlights also have a 194 bulb in them on the inner side of the headlight bulb. I have seen them in person. You can see where the bulb harness is from behind and you dig ? -------------------- |
Oct 24, 2005 - 10:29 AM |
Interesting info Batman, I never knew that.
Oct 24, 2005 - 10:53 AM |
Wow, thanks Dustin, I did not know that either
Oct 24, 2005 - 10:56 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Ehm... JDM ones (the regular ones) DO have the wrong Cut out They are RHD so cut out of the normal JDM lenses will bling outcoming trafic on LHD cars... This is the main difference..
-------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Lo-Fi Version | Time is now: January 14th, 2025 - 6:27 PM |
