> NO NO NO SWEET JESUS NO!!!!!!, valve stem seals
post Oct 23, 2005 - 10:45 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
I have a horrible feeling. I can't get the car to stop smoking in start. Lets out a nice white puff everytime..atleast it seems damn white also could be wishful thinking. Car takes a while to get to the power. I mean it has to be up to full temp to get decent power. I am fearing valve stem seals fearing them like an STD. Car has now 158,000 coolant seems to be not leaking. Changed the oil very recently and will be keeping an eye on it. Any suggestions? Note this is on the 6th gen not the 4th.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Oct 23, 2005 - 10:51 PM
White smoke typically indicates burning coolant, a sign of head gasket failure.
post Oct 23, 2005 - 11:14 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
but at start up of after idle for a little. its simple valve seals!
post Oct 23, 2005 - 11:25 PM
Agent21
Joined Sep 12, '05
It is right after start up frown.gif then stops one big puff
94 GT Liftback
post Oct 23, 2005 - 11:28 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Most likely your head gasket. When you shut the car off, the pressure in the cooling system pushes a small amount of water into your combustion chamber. You start the car up, and poof, it burns off. The coolant can't really leak in while it's running, that's why it only happens at startup.
That is, if it is white smoke. If it's blue, then it's the valve stem seals most likely.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 23, 2005 - 11:47 PM
creis
Joined Jan 10, '04
From Shoreline, WA
I had this issue right after my swap, just a little bit of white smoke poofed out the back on startup. my warentee in hand took it to the mechanic and had them replace the valve guides, seals and gasket, allong with fully machining he head all free of charge. witch solved the problem
Lo-Fi Version Time is now: November 25th, 2024 - 3:52 AM
