> for: 5spd swappers, or people that just know, need some info about pedals
post May 8, 2003 - 11:56 PM
Mynzeyes
From Franklin/Nashville, TN
just wonderin if the clutch/gas/brake pedals bolt right into the auto body, of if something needs to be drilled/tapped. i am NOT askin about the wires just yet, just the hardware.
soooooo, not really cable material, just will the pedals bolt right into place?
-John-
AIM==Mynzeyes
post May 9, 2003 - 12:50 AM
Xpander
Joined Sep 5, '02
From Winter Haven, FL
Everything bolts right into place. The only thing you will have to do is punch a hole for the clutch. If you get down and look at how the pedals are set up you'll see what I mean. Pull back the carpet/padding and you'll see the outline of where the clutch pedal bracket should go (2 small holes for the bolts, 1 big hole for the clutch).
All you need is just the brake and clutch pedal, don't need a new gas pedal. I got my stuff through TAP Recycling. They've been pretty good for me.
Hope that helps you out
Colin
post May 9, 2003 - 12:57 AM
Mynzeyes
awesome! thanks man
i already got the pedals, i got all 3 + the shifter boot and plastic surround for 100 shipped, so that was a BOMB price. and about the hole i punch, any clue what size bit i need, and also is there ANYTHING at all on the other side i need to be weary of?
-John-
AIM==Mynzeyes
Lo-Fi Version Time is now: December 1st, 2024 - 6:46 AM
