Enthusiast ![]() Joined Oct 3, '04 From NC Currently Offline Reputation: 0 (0%) ![]() |
ok guys when i'm shifting gears there is a slight knock that has started to worry me. the tranny is not slipping and it still pulls hard, the front and back mounts are new the others are the originals. i have no clue what could be causin this knockin, any ideas on what my problem could be? thanx in advance
is it grinding? Have you checked the shifter cables? Is the shifter assembely bolted down correctly? Is the noise in the tranny or is it in the shifting assembely?
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
see if the clutch it going out, then also see if the clutch has the same pressure it used to ( low fuild or air in the lines) then look into flushing tranny fluid with synthetic and if that wont fix it then you may have bad synchros. also a simple fix like he said check the shifter cables make sure nothing is obstructing it.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) ![]() |
I had this problem on my 86 GT and now my 96st, The Nut on the bottom of the Knuckle came loose and is a loud clunking each time I shift because of shifting weight. Rip off the wheel and look under there and you can tell, if it is it I remember it being a 17mm and just crank on it.
DTE -------------------- I am a thief.
do not buy anything from me. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
My car does it too, but its coming from the downpipe from my swap. It looks like the downpipe is hitting against the car and the clearance is like a few CM apart.
Check that, It does it when idling as well, or when you shift car weights. |
i check the cables this morning as and far as i can tell they are tight, however i put the car of some ramps and got my brother to do the shifting while i was outside listening and it's definitely coming from the tranny. its not slippin, the feels preassure is the same and the fluid levels are fine. i"m thinkin to just gonna drive till something goes wrong.
noice got louder so i got under the car, the mount on the tranny was spilt even though it is only about 3 months old. took it to advance, they defected it and got a new one and problem solved
Lo-Fi Version | Time is now: February 24th, 2025 - 9:23 AM |
