> 7AFTE oil feed line?, how long is yours
post Oct 28, 2005 - 5:21 PM
dans_st
Joined May 24, '03
From Andrews TX
How long is the oil feed from your block to your turbo?
mine is pretty long(around2.5') and I don't know if it should be shorter, and if not where did you route yours through?
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Oct 28, 2005 - 5:26 PM
nik
Joined Sep 30, '02
with where your turbo is hanging you only need a foot to 15" of line
i'll use clements pic as an example because your using the same manifold (well maybe)
from the turbo to just left of the oil filter is all the line you need
This post has been edited by nik: Oct 28, 2005 - 5:31 PM
post Oct 28, 2005 - 6:56 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
make sure to use a restictor!
Lo-Fi Version Time is now: January 15th, 2025 - 8:57 AM
