> 3SGTE Swap Checklist
post Oct 29, 2005 - 5:03 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
3SGTE Swap Checklist:
Engine set - $2500
Custom wiring harness from Phoenix Tuning - $350
FMIC - $225
FMIC Piping (4 45* bends, 5 90* bends, couplings and t-bolt clamps)- $300
Auto/manual parts (shifter assembly, cables, master cylinder, clutch lines and pedal assembly) - $300
Passenger side GT mount - $75
Fuel pump - $100
Aftermarket dowpipe - $150
GT a/c lines
GT p/s lines
Custom bracket for clocked turbo
Custom coolant hose (ST)
E153 Tranny - $550, LSD E153 closer to $900
ST205 tranny mounts and brackets (or custom)
3SGTE Clutch Kit - $170
MR2 or Solara inner axles, ST205, Camry, or maybe ST185 outers
MR2 Center axle carrier
FWD tranny linkage conversion (for MR2 tranny)
ST205 or GT shifter cables
S54 Tranny - $350
Clutch kit - S54 clutch plate, TOB; 3SGTE pressure plate and flywheel (machined) $150 or
Custom clutch kit from Spec (good to 420 ft/lbs)- $400
GT axles including center carrier - $120
Front, rear, driver's side GT mounts and brackets
GT shifter cables
Misc stuff- $800
Optional Items:
P/S cooler
Gaskets, belts, and maintenance items
Guages
Anything I missed, and any clarification on the pricing?
This post has been edited by Dr_Tweak: Oct 29, 2005 - 11:00 PM
Click here to see my swaps
drtweak@phoenixtuning.com
post Oct 29, 2005 - 6:24 AM
jgreening
Joined Jan 17, '04
From Illinois
guages, exhaust, alternator bracket
post Oct 29, 2005 - 10:38 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
axle carrier braket, engine gasket set, resurface the flywheel, fluids, converted harness
tools, cherrypicker, torque wrench, garage, dollies
Research...... and time a good amount of time
DEF
I will return one day.
post Oct 29, 2005 - 11:31 AM
That $550 for E153 is a NON-LSD transmission. I bought my 93+ LSD for $900
post Oct 29, 2005 - 1:01 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
205 mounts don't work.
FMIC not NEEDED but highly reccomended.
axles cost me 100.00 (GT's)
spec clutch is reccomended. mine cost just under 400. good for 420tq.
*my swap*
i needed an electronic speed sensor (still do!)
when ordering motor mounts, make sure you get the brackets for example, i have the right tranny (from a 92) and the mount (1995GT) wouldnt bolt to the tranny w/o the 1995 GT bracket under it.
do all maintance and repair you could before you stick it back into the car. water pump and timing belt should be at the top of that list! my belt was very brittle and starting to shred.
a good helper! def. a must have..
i will add more when it comes to mind!
post Oct 29, 2005 - 10:53 PM
Dr_Tweak
Joined Mar 31, '04
Okay I updated the thread with some of that.
QUOTE(jgreening @ Oct 29, 2005 - 11:24 AM)
[right][snapback]350311[/snapback][/right]
What alternator bracket?
QUOTE(zipstrips @ Oct 29, 2005 - 6:01 PM)
*my swap*
[right][snapback]350388[/snapback][/right]
What do you mean the ST205 mounts don't work? I did a ton of research on this and that's what I though the conclusion was. Which mounts work?
This post has been edited by Dr_Tweak: Oct 29, 2005 - 11:01 PM
post Oct 29, 2005 - 11:15 PM
205 mounts work for E153.
204 mounts work with S54
Alternator tension bracket only necesary if you buy the engine without an alternator.
post Oct 30, 2005 - 8:35 AM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
we should sticky this
post Oct 30, 2005 - 1:58 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Supersprynt @ Oct 29, 2005 - 11:15 PM)
[right][snapback]350538[/snapback][/right]
Or if you buy an MR2T clip to get the transmission too.
post Oct 31, 2005 - 11:47 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
i have a huge list of partnumbers from my st to 3sgte swap if anyone is intrested... i'll have to narrow it down to the bare min. to complete it thou unless u guys want to see my tuneup parts etc.
post Nov 1, 2005 - 12:14 AM
Dr_Tweak
Joined Mar 31, '04
post Nov 1, 2005 - 12:15 AM
timing belt
water pump and gasket
rear main seal
hose from hell
hose from hell on earth
valve cover gasket
consider new valve cover bolts from twosRus, because the stock screws just come loose and leak tons of oil.
new axel seals for the tranny
This post has been edited by lagos: Nov 1, 2005 - 12:18 AM
post Nov 1, 2005 - 12:55 AM
Dr_Tweak
Joined Mar 31, '04
Definition of hoses from hell?
post Nov 1, 2005 - 1:27 AM
hose from hell is the small coolant hose thats right behind the downpipe, and hell on earth is the rubber hose that goes to the oil cooler.
they got that nick name from the mr2 guys, cause they normally leak at around 100,000miles and u have to take off the downpipe and sometimes even the turbo just to get to it.
Lo-Fi Version Time is now: January 13th, 2025 - 2:49 AM
