> Abs light on!, Some advice plz
post Nov 2, 2005 - 8:26 AM
Craig
Joined Sep 2, '05
From England, Uk
how are u all? well i had my clutch replaced yesterday i went to pick the car up as i was driveing off down the road i looked at the dash board and bam there it was the abs light was on frown.gif so this moarning i had a qwick look over the car i had the hood up and normaly when i turn the ignition on u here the abs pump kick in but nothing apart from i could here the reley box clicking away. Any idea's people?
Thanx Craig
post Nov 2, 2005 - 11:39 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Craig @ Nov 2, 2005 - 8:26 AM)
Thanx Craig
[right][snapback]351838[/snapback][/right]
Read the codes buddy, and it should tell you what sensor the monkeys who fitted your clutch have broken.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Nov 2, 2005 - 11:53 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
my abs light is on as well but because i replaced my bad gt hub with a st hub. obviously the gt version has abs and the st does not. but as long as i hear no noise, i am happy.
post Nov 2, 2005 - 12:46 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(LewFX @ Nov 2, 2005 - 11:53 AM)
[right][snapback]351925[/snapback][/right]
Unfortunately, it's a MOT failure in the UK.
JDM ST205
post Nov 3, 2005 - 5:51 AM
Craig
Joined Sep 2, '05
From England, Uk
only problem is m8 ive got an apexi ecu m8 and ive tried to look for error codes before but it wont show them frown.gif the cars going back to the place i had the clutch done on saturday so will have to see wot they say if worst comes to worst im gonna have to take the bulb out frown.gif
craig
This post has been edited by Craig: Nov 3, 2005 - 5:52 AM
post Nov 3, 2005 - 10:12 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
I bet they knocked your speed sensor loose or forgot to connect it. I think it is down by the flywheel been a while since I looked. Even if they broke it it should be fairly cheap I think.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Nov 3, 2005 - 10:25 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Craig @ Nov 3, 2005 - 5:51 AM)
craig
[right][snapback]352427[/snapback][/right]
ABS ECU is a totally different system to the Engine ECU.
Read your ABS codes.
JDM ST205
post Nov 3, 2005 - 10:48 AM
Craig
Joined Sep 2, '05
From England, Uk
how do i check thos m8 the same way u check the engine codes? Tc and E1 terminals?
thanx craig
post Nov 3, 2005 - 11:46 AM
QUOTE(Craig @ Nov 3, 2005 - 11:48 AM)
thanx craig
[right][snapback]352507[/snapback][/right]
94-95
ignition in the ON position,
bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light
codes 31-34 are the sensors @ each wheel.
31 Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector
32 Malfunction of left front wheel speed sensor signal. Check
33 Malfunction of right rear wheel speed sensor signal. Check
34 Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector
post Nov 3, 2005 - 12:16 PM
Mr_E
Joined Nov 16, '04
From UK
This link was most useful when I was going through my ABS hell.
http://www.forparts.com/ICabstoycorolla03.01.htm
JDM ST205
post Nov 4, 2005 - 4:02 AM
Craig
Joined Sep 2, '05
From England, Uk
well i checked for codes on the abs last night and the light did not flash it just stays on constant. any idea's peeps?
thanx again craig
post Nov 4, 2005 - 11:18 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Craig @ Nov 4, 2005 - 4:02 AM)
thanx again craig
[right][snapback]352935[/snapback][/right]
You bridged TC and E1, turned the ignition on and got no codes? But the ABS light is on?
WTF?
If you bridge correctly and have no codes, the light should flash rapidly. I suspect it wasn't a good bridge.
Did you remember to pull the short pin as described in the link I posted?
JDM ST205
post Nov 4, 2005 - 11:27 AM
Craig
Joined Sep 2, '05
From England, Uk
ya but i did'nt do it like it said in that pick so im gonna try it again when i get in wot i did was with the ignition off pulled the fuse out bridged the connections then turned the ignition on like i said it did'nt do nothing just stayed on constantly but ive just been going over that web site and it says with the ignition on pull fuse and then bridge the connections. Also another thing m8 before i had my clutch done i use to here the abs unit kick in when i turned the ignition on but now all i can hear when i turn the ignition on is the reley box clicking its ass off.
thanx craig
post Nov 4, 2005 - 1:32 PM
Mr_E
Joined Nov 16, '04
From UK
JDM ST205
Lo-Fi Version Time is now: February 20th, 2025 - 2:11 PM
