> diff size rims...
post Nov 2, 2005 - 6:59 PM
Valo666
Joined May 15, '05
From Toronto
So, im looking into gettin a set of rims. I found a few sets i like, and i wanna get somethin wider than a 7", at least for the back to fill in the big gap under the wheel well. Any ways, my question is, if i go with a set of 17x8 in the rear and 17x7 in the front, would it make my car handel weird/would it effect the ride because of the diff size rim??
post Nov 2, 2005 - 7:29 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I'm not sure if it would make your car handle or ride weird.
I cant seem to remember that has done this before to a fwd.
People normally have bigger wheels at the back if it was rwd.
I reckon you should go with 17x8 all round.
That way they will fill the gap under the wheel well.
6GC 4 Life Baby!!!
post Nov 2, 2005 - 7:35 PM
I wouldn't have different wheel widths. If you're really concerned about filling up the wheel wells, get wheels with a suitable offset.
post Nov 2, 2005 - 7:57 PM
celiracer
Joined Oct 5, '05
From NE
I'd say just go 17' X 8 all the way around.
post Nov 2, 2005 - 11:08 PM
J-TYPE
Joined Mar 16, '05
From Toronto, Ontario
i'd say 17x8 all around too because you can rotate the tires also
post Nov 3, 2005 - 12:49 AM
airswoosh1
Joined Oct 21, '05
From Los Angeles, CA
Don't mr2s come with different size wheels in the back and front? Why? What's the advantage?
'94 Tercel
USDM 5EFE * OEM MR-S Rims * Kumho ECSTA ASX 205/50R15 * NST Short Shifter
estabon anti-lift plates * KYB GR2 Shocks & Struts * Eibach Pro Kit * Whiteline Rear Sway Bar
Paseo Sway Bar * Paseo Front Brakes * Momo Shift Knob * Paseo Front Seats
JDM OEM Toyota Altezza Side Markers * Corsa Tailights * Corsa Grille * Corsa Trunk Garnish
http://www.socaltercel.com
post Nov 3, 2005 - 12:53 AM
CelicaZR
Joined Mar 25, '05
QUOTE(airswoosh1 @ Nov 3, 2005 - 4:49 PM)
[right][snapback]352372[/snapback][/right]
I dont think MR2s have different size wheels.
But I could be wrong.
MR2 are rear wheel drive so they can have bigger wheels at the back to
get better traction.
6GC 4 Life Baby!!!
post Nov 3, 2005 - 3:09 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
If you had bigger wheels in back you wouldn't be able to rotate your tires like you can with same size all around.
**** Photobucket
Lo-Fi Version Time is now: February 22nd, 2025 - 3:40 AM
