> Anti Lock System, yes i know again.... can anyone help...
post Nov 3, 2005 - 3:19 PM
Phantom4
Joined Oct 18, '05
From |-CAN-ADA-|
Hey guys can anyone help !!!
but the ECU codes start only from 11
Code 11
Open in solenoid relay circuit. Check actuator wiring
harness, solenoid relay, solenoid relay wiring harness and solenoid
relay connector. See SOLENOID RELAY under COMPONENT TESTING.
Code 12
Short in solenoid relay circuit. Check actuator wiring
Code 13
Open in pump motor relay circuit. Check actuator wiring
harness, pump motor relay, pump motor relay wiring harness and pump
motor relay connector. See MOTOR RELAY under COMPONENT TESTING.
Code 14
Short in pump motor relay circuit. Check actuator wiring
Code 21
Open or short circuit in solenoid for right front wheel.
Check actuator solenoid, wiring harness and connector. See ACTUATOR
CHECK under DIAGNOSIS & TESTING. See ABS ACTUATOR under COMPONENT
TESTING.
Code 22
Open or short circuit in solenoid for left front wheel. Check
actuator solenoid, wiring harness and connector. See ACTUATOR CHECK
under DIAGNOSIS & TESTING. See ABS ACTUATOR under COMPONENT TESTING.
Code 23
Open or short circuit in solenoid for right rear wheel. Check
Code 24
Open or short circuit in solenoid for left rear wheel. Check
Code 31
Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector. See SPEED
SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See FRONT SPEED SENSORS
Code 32
Malfunction of left front wheel speed sensor signal. Check
Code 33
Malfunction of right rear wheel speed sensor signal. Check
SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See REAR SPEED SENSORS
Code 34
Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector. See SPEED
Code 35
Open in left front or right rear wheel speed sensor circuit.
Check speed sensor, sensor rotor, wiring harness and connector. See
SPEED SENSOR DIAGNOSTICS under DIAGNOSIS & TESTING. See appropriate
speed sensor testing under COMPONENT TESTING.
Code 36
Open in right front or left rear wheel speed sensor circuit.
Code 37
Rear speed sensor rotor malfunction. Check rear sensor
rotors.
Code 41
Battery voltage is less than 9.5 volts or more than 16.2
volts. Check battery and voltage regulator.
Code 51
Actuator pump motor is locked or pump motor circuit open.
Check pump motor, pump motor relay, vehicle battery, actuator wiring
harness, connectors, actuator pump motor circuit and actuator ground
bolt. See ACTUATOR CHECK under DIAGNOSIS & TESTING. See MOTOR RELAY
ABS Light Always On
Malfunction of ABS ECU. Inspect ABS ECU connector for proper
installation and undamaged terminals. Repair as necessary. If
connector is okay, temporarily substitute known good ABS ECU. Retest
system.
anybody know anything please reply before monday nov.07 , I am going to Toyota dealership to check it out and it is EXPENSIVE !!!
pleaze anydoy
Thanx in advance !!
post Nov 3, 2005 - 4:38 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
You can start by having one of the mods delete one of the two posts you just made..
**** Photobucket
post Nov 3, 2005 - 10:39 PM
was this on your CEL or your ABS light ? they are different ECUs and throw different codes...
is your ABS light on all the time ? are you just getting a CEL ?
post Nov 4, 2005 - 4:32 AM
Phantom4
Joined Oct 18, '05
From |-CAN-ADA-|
what is a CEL ???
yes my ABS light is always on, tried restarting the system by bridging E1 & TC but the light came on again !!!
This post has been edited by Phantom4: Nov 4, 2005 - 4:33 AM
post Nov 4, 2005 - 11:16 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Phantom4 @ Nov 3, 2005 - 3:19 PM)
but the ECU codes start only from 11[right][snapback]352618[/snapback][/right]
How can a light flash 0 times?
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Nov 4, 2005 - 11:38 AM
95CelicaST
Joined Feb 5, '05
CEL= Check Engine Light
**** Photobucket
post Nov 4, 2005 - 5:22 PM
QUOTE(Phantom4 @ Nov 4, 2005 - 5:32 AM)
what is a CEL ???
[right][snapback]352939[/snapback][/right]
you dont reset it by bridging the connectors.
that is how you get the codes.
bridge e1 & tc1 with the car in the on position.
it IS not code 09 there is no such code.
post Nov 7, 2005 - 12:45 AM
Phantom4
Joined Oct 18, '05
From |-CAN-ADA-|
ok i found out what my problem is ....
code 31 and 32 both front sensors
choice 1 : $800 to fix it ...
choice 2 : $0 to take out the bulp
i went with choice 2
thanx everybody !!! props
post Nov 7, 2005 - 12:46 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
The wiring was probably loose/disconnected.
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 7, 2005 - 10:17 AM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Phantom4 @ Nov 7, 2005 - 12:45 AM)
[right][snapback]354024[/snapback][/right]
And 5K when you stand on the brakes, hit some derv, lose the back end and wipe the car out.
I fixed my sensors.
JDM ST205
Lo-Fi Version Time is now: January 8th, 2025 - 10:15 AM
