> Underdrive pulley= bad?
post May 10, 2003 - 2:54 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
I've been doing some research and have heard lots of people saying that removing the stock pulley is bad because it is designed to absorb the harmonic oscillations from the engine. The stock pulley apparently has a rubber ring, designed to do this. So, by replacing the pulley with one that isn't designed to do this (none are), you can decrease the life of your engine for only moderate gains.
Anyone have any problems with their Underdrive pulley or know if Toyota engines come equiped with this rubber ring?
post May 10, 2003 - 4:43 PM
1bwilson
Joined Aug 30, '02
From Maryland
Have had my UD pully for 3 years and nothing yet. Also I have never encountered anyone who has dispite the rumors.
-Bryan-
Member of Team 5sfTe
post May 11, 2003 - 1:18 AM
HyperDeathKill
Joined Apr 20, '03
From Chicago
Bryan did you happen to see if such a rubber ring exists on the stock pulley?
post May 11, 2003 - 12:59 PM
ghostdog
From ny to philly
QUOTE (HyperDeathKill @ May 10, 2003 - 10:32 PM)
I don't think there was a rubber ring around the stock pulley. I'm not gonna pull it out and check, but I'm pretty sure there wasn't.
also, don't worry about the harmonic balancers yadda yadda. as long as you get a well manufactured pulley (ie: asp or ud) you will be fine.
Lo-Fi Version Time is now: November 25th, 2024 - 11:31 AM
