> highest rpms on a 3sgte??, swapped in
post Nov 5, 2005 - 9:42 AM
cyb593
Joined Feb 22, '04
From USA
i have it swapped into a 90 gts i was wonderin what is the highest rpms i can go or where does it red line??
post Nov 5, 2005 - 10:12 AM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
I'm not really sure but I have an ST205 cluster in my Celica ST and it shows the redline as 6,900 RPM. I don't know if that's correct, but here's a pic: http://www.6gc.net/forums/index.php?showtopic=30355
This post has been edited by JoKeRkId613: Nov 5, 2005 - 10:13 AM
post Nov 5, 2005 - 10:43 AM
Mr_E
Joined Nov 16, '04
From UK
Stock, redline is about 6500. Runs out of puff about 6200.
Modified, I know of engines that run to 8500 rpm.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Nov 5, 2005 - 12:56 PM
QUOTE(Mr_E @ Nov 5, 2005 - 10:43 AM)
[right][snapback]353432[/snapback][/right]
huh? redline is more areound 7300 or just 7grand on a 3sgte.
post Nov 5, 2005 - 1:39 PM
According to this ST205 cluster its 6800.
post Nov 5, 2005 - 2:15 PM
its just how they made that gauge cluster. they normally start the redline a little bit before the point the motor can really rev to. you can see that this one from a turbo mr2 reads right at 7grand. i think the true redline (where the rev limiter is set at) is 7300 rpm.
This post has been edited by lagos: Nov 5, 2005 - 2:16 PM
post Nov 5, 2005 - 2:45 PM
Mr_E
Joined Nov 16, '04
From UK
Wouldn't know, I've never hit the limiter. Turbo runs out of shove before then.
JDM ST205
post Nov 8, 2005 - 2:25 PM
djr97
Joined Mar 25, '04
From Germany
i have been in the red range several times, up to around 7200-7300 rpm, and the limiter never came on. so i think lagos is right.
although, mr_e is also right: you can go up there but it doesn't make sense because the turbo is said not to be very effective above 6000. max power output (hp) is reached at 6000 rpm on a stock engine.
post Feb 15, 2007 - 7:59 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(lagos @ Nov 5, 2005 - 12:56 PM) [snapback]353467[/snapback]
For a 2nd gen, yes.
A 3rd gen might be as well, but it also could be lower....
Remember, there are alot of differences in the 2 gens.....
Lo-Fi Version Time is now: February 23rd, 2025 - 12:39 PM
