> Radiator Question???, koyo install????
post Nov 6, 2005 - 10:44 PM
dans_st
Joined May 24, '03
From Andrews TX
I was installing my Koyo radiator today and I don't know what the other hole next to the lower radiator hose is- it is threaded and about 3/4"
Does anyone know what this is for?
If it's not for anything I was considering putting a coolant sensor in it and running that to it's own guage, BUT would I get a proper reading of the engine's temp from there?
Or can/should I just find a plug for it?
Thanks-Daniel
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Nov 6, 2005 - 10:55 PM
there should be a temp sensor on your old radiator right there. you probably have to swap it over. that sensor is what tells your radiator fans to come on .
post Nov 6, 2005 - 11:04 PM
dans_st
Joined May 24, '03
From Andrews TX
I have my car at in brothers shop, Does the ST have one confused.gif ? I'll check for the sensor tomorow- I didn't notice onebut I was trying to get alot done on the car today biggrin.gif
post Nov 9, 2005 - 12:36 AM
dans_st
Joined May 24, '03
From Andrews TX
My car doesn't have the sensor?, I think because it is an ST -
I know other people have this radiator on an ST,What did you guys use?
I'm thinking of just buying a temp.sensor for the GT and running it to an aftermarket guage-will that work without any complications?
post Nov 9, 2005 - 3:25 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
If you really cant find a place to plug in a sensor, just plug it.
post Nov 9, 2005 - 11:55 AM
dans_st
Joined May 24, '03
From Andrews TX
CheesyLobster  Posted Today, 02:25 AM
the problem is I don't have a sensor to put in the hole
post Nov 9, 2005 - 12:04 PM
nik
Joined Sep 30, '02
QUOTE(dans_st @ Nov 9, 2005 - 9:55 AM)
[right][snapback]354978[/snapback][/right]
plug it with a short bolt and rubber washier then
Lo-Fi Version Time is now: November 28th, 2024 - 4:44 AM
