heater fan, making lots of noise... |
Nov 9, 2005 - 2:06 PM |
Enthusiast Joined Nov 8, '05 Currently Offline Reputation: 0 (0%) |
when i turn my heat on (climate controls inside car) it makes awful noises, kinda like a leaf stuck in the fan, i don't think that's the issue, but what else could it be.... anything expensive? i'm going on a trip this weekend (only a 2 hour drive) but i don't want to be cold the whole way!! is it something i could fix myself? Where is the fan located, somewhere easy to access?? hopefully... thanks in advance guys!
Nov 9, 2005 - 4:05 PM |
Enthusiast Joined Mar 25, '04 From Germany Currently Offline Reputation: 0 (0%) |
the fan is located behind/under the glove box. you have to remove the glove box to access the fan motor. it's mounted with some screws and is easy to exchange.
i've already had the same problem with two celicas. both motors became very noisy and i exchanged them with used parts from ebay. 5th-gen fans also fit (and probably some other models) only the electric connector is a little different. but that can be fixed very easily |
Nov 9, 2005 - 4:08 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
I have the same problem. My blower motor is shot. Is located under the dash in the passanger side. I got quoted for the motor its self, its $120CND, so maybe $80 or $90 usd
Nov 9, 2005 - 9:13 PM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
found it, fixed it (wd-40) works like a charm
Lo-Fi Version | Time is now: December 2nd, 2024 - 9:46 AM |
