> The serious stuff starts soon....
post Nov 9, 2005 - 10:49 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Next Tuesday is the start of some serious mods for the 4. Engine and box are being pulled out in readiness for the next step...
Bench flowed cylinder head with HKS 264 cams, adjustable cam wheels and uprated valve springs. Will also look at the inlet manifold when it's off to see if the flow can be imprioved. Block to have oilways cleaned up (rough castings as standard) to improve flow and will be reassembled with fully balanced crank, TRD shells, OE rods and ACL pistons (0.5 oversized). That will be coupled to a lightweight flywheel and uprated clutch. This will allow the rev limit to be increased to at least 8000rpm.
Will also be fitting some GReddy 750cc top feed injectors too and a much bigger Koyo aluminium rad. Once this is all put together, boost will be turned back down and the engine will be given time to run in properly. Will also give me chance to sort out a decent intake system using an A'Pexi filter and custom made carbon fibre cold air box.
Then, once I get back from Europe, I can look at a tubular exhaust manifold, BB turbo (probably a GT30) and an A'Pexi ECU. As for power, no idea what to expect until it's been on the dyno, but see no reason why an 11.xx sec 1/4 mile shouldn't be possible biggrin.gif
Gary
This post has been edited by GT4WRC: Nov 9, 2005 - 10:54 PM
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
post Nov 9, 2005 - 10:52 PM
sounds awesome. make sure to take lots of pics and keep us updated on your progress
post Nov 10, 2005 - 12:04 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I cant wait to see this. Take as many pics as you can.
I will return one day.
Lo-Fi Version Time is now: February 18th, 2025 - 4:41 PM
