> ABS HELP AGAIN PLZ!
post Nov 14, 2005 - 4:58 AM
Craig
Joined Sep 2, '05
From England, Uk
well guys as u no from my last post i had my clutch changed on my st205 and ever since then the abs light as been on frown.gif now i use to here the abs unit kick in when i turned the ignition on but now all i can hear is the reley unit clicking when i turn the ignition on well i took the car back to the garage were i had the clutch done and he thinks its a fuse thats blown some were because he tested the abs unit its self and it worked so my question is apart from the 3 fusses in the engine bay are there any more any were else on the car? or do u think the guy is telling me a bunch of lies? also does any one have a wireing diagrame of the abs unit?
thanx craig
also if there is a wheel sensor that has had it will the abs unit still work or will it shut its self down?
post Nov 14, 2005 - 7:30 AM
if a sensor is blown the ABS light will stay on, indicating it has a code stored in memory.
do you know how to check the codes?
post Nov 14, 2005 - 8:52 AM
Craig
Joined Sep 2, '05
From England, Uk
ya im gonna check them tonight m8 also if there is a sensore down and a code stored will that stop the abs working all together? or does it just stop that senssor from working? cause the abs does not work at all. and like i said the guy tested the abs pumped and its fine and he thinks there is a fuse some were in the car that as gone?.
Thanx vry much craig
post Nov 15, 2005 - 12:39 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(Craig @ Nov 14, 2005 - 8:52 AM) [snapback]355378[/snapback]
Any fault code on the ABS system will disable it entirely.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
Lo-Fi Version Time is now: December 11th, 2024 - 8:43 PM
