7afe/5sfe swap, Interesting |
Nov 14, 2005 - 8:09 PM |
Enthusiast Joined Sep 14, '05 Currently Offline Reputation: 0 (0%) |
Okay, I have a 94 celica st. Decent little car but I blew the motor up in it. So I decided to swap a 5sfe because anything bigger is harder than **** to find around Hamilton, OH. Anyways, I got the 5sfe and have started putting it in. It blows my mind how many things are different between the two motors. I have had to customize so much on this piece. Now, after I have the motor mounted and everything I find that I have to either get a hood with a scoop and fabricate a scoop on my stock hood to clear the intake on the 2.2 because it sticks up about an inch and a half over the engine compartment. I also am finding out that a header for this motor is darn near impossible to find, so my brother-in-law and I are going to make one. We are using 10 gauge high grade steel tubing for this, I'll post pics when it's done. All I need is to hook up the wiring and finish the exhaust and then it's done. If anyone has ever done this I'd love to hear about how you did it, because it hasn't been as fun as I would have hoped. I know nobody else probably cares to read this but it's my first time posting here so there!
Nov 14, 2005 - 8:25 PM |
i think you did something wrong with the motor mounts. the 5sfe motor should sit just like it does in a gt engine bay, you should be albe to close the hood without any problems or mods.
Nov 15, 2005 - 12:33 PM |
hook up the wiring??? I think you are wrong, the wiring on the GT are completely different on an ST.
Are you sure you know what your doing? |
Nov 15, 2005 - 1:14 PM |
Enthusiast Joined Dec 2, '04 From Surrey, England Currently Offline Reputation: 0 (0%) |
the bonnet and front bumper are different on the gt4 than st to allow for the bigger engine. If you fitted a gt4 hood on an st you're left with a gap about an inch thick.
Maybe this of use, maybe not! Good luck either way! Dan |
Nov 17, 2005 - 2:10 PM |
did you fabricate engine mounts or did you buy GT mounts? If you fabbed them, then there is your clearance problem. Go get some GT mounts from a junkyard and do it right.
EDIT: Also, you know that the 5S harness isnt plug and play with a 7A right? This post has been edited by 95CelicaST: Nov 17, 2005 - 2:12 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Nov 17, 2005 - 3:36 PM |
Yes, I know the harnesses and ECU's are different, I can handle that. An ECU for the GT isn't hard to find and the wiring harness I got with the motor I mean, that's pretty straight forward, just routing wires and plugging all the sensors back in. I made one of the engine mounts, the one on the passenger side of the car and I'm pretty sure that is the problem with clearing the engine bay. But, I think it will look alright with a hood scoop on it.
I know it's not a 6th gen, but does anyone know anything about the 89 GTS celicas? I found one for sale and would like to know how good the motor and trans was back then? And as far as whether or not I know what I'm doing, well my other car is a 73 Cutlass with a 454 Big Block, so no probably not, I'm used to older bigger motors. But, I think I'm doing pretty well. |
Nov 18, 2005 - 2:57 PM |
Yeah, I know my way around old cars and engines better than the new ones. I had a 1974 Ford F-250 that was street raked and had a build 460 big block in it. It was a pity I had to let her go, but 6 miles to the gallon is not anything I would consider economical...
This post has been edited by 95CelicaST: Nov 18, 2005 - 2:57 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Lo-Fi Version | Time is now: January 15th, 2025 - 6:50 PM |
