> EGR???, cel
post Nov 14, 2005 - 8:22 PM
dlx742
Joined Oct 10, '05
From San Diego
so my cel has been on and off (now you see it now you dont status) since i put my CAI in. and i thought it was just because it was an aftermarket intake and that stuff normally happens so i never checked my OBD.
well today i finnally got around to checking it and there error is "egr low flow"
so now my question is... how in the world do i fix this?
i know what the egr is and that there is probably a clog in a vacuum line somewhere, but what do i do now
post Nov 15, 2005 - 12:29 AM
DJWashington
Joined Aug 2, '05
QUOTE(dlx742 @ Nov 14, 2005 - 8:22 PM) [snapback]355603[/snapback]
Well i had Toyota tell me that mine was my problem. So i looked for one unnsucessfully, broke down and bought one from advanced auto for $186.00. Put it on, and it fixed nothing frown.gif . I tried taking it back and they wont because i have already used it. Bastards............ So make sure its going to fix your problem before you go and buy a new one if you have to.
1994 GT Awaiting new tranny...
...I love my girlfriend...
post Nov 15, 2005 - 9:53 AM
toyotatech
Joined Jun 14, '05
From colorado
check vacuum lines from egr to vsv make sure there not cracked or hanging off
post Nov 15, 2005 - 11:46 AM
QUOTE(toyotatech @ Nov 15, 2005 - 9:53 AM) [snapback]355803[/snapback]
yup, and if all checks out there, you can remove the EGR valve and pipe, and clean them out.
post Nov 15, 2005 - 12:31 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Heres some things to check for.
1.) ECU Temp sensor on intake
2.) Charcoal canaister
3.) Vaccum lines
4.) Map Sensor
If all, it must be the ECU temp or the canasister. Otherwise do a reset on the ECU and see what happens if you haven't done that yet.
post Nov 16, 2005 - 9:59 AM
toyotatech
Joined Jun 14, '05
From colorado
if the vacuum lines are ok i would bet its the vsv hardly ever the egr and the charcoal canister has nothing to do with an egr code. if you want i can get the manual for that code and email it to you, it tells every thing you need to check and how.
post Nov 16, 2005 - 5:39 PM
dlx742
Joined Oct 10, '05
From San Diego
that would be great
thnkz a lot
post Nov 16, 2005 - 7:16 PM
toyotatech
Joined Jun 14, '05
From colorado
whats your email address
post Nov 16, 2005 - 10:15 PM
dlx742
Joined Oct 10, '05
From San Diego
dlx742@yahoo.com
Lo-Fi Version Time is now: January 16th, 2025 - 8:52 AM
