> Tyre Wear..., ...on performance cars.
post May 12, 2003 - 1:52 AM
jaq1967
Joined Apr 28, '03
From London
Stupid question perhaps?
Do tyres wear out more on the inside of the wheels more than on the outside (I'm talking on fat racing wheels), or is that to do with the tracking of the car needing adjusting?
Somebody fed me this info and I thought 'bollox, don't believe you!'. Should I believe or sort tracking out?
jaq1967
post May 12, 2003 - 2:04 AM
Mynzeyes
From Franklin/Nashville, TN
it has to do w/ a camber problem when a car is lowered excessively w/o being aligned and straightened out. when you drop the car X amount, it changes all the angles, and the tops of the tires tend to lean in, therefore causeing the inside of the tire to take all of the contact on the road, and sometimes the outside doesn't even touch the road, thus causing the excessive wear on the inside smile.gif. but, if taken care of, this will not happen. if you lower the car or somethin like that, be sure to get it aligned. wink.gif.
-John-
AIM==Mynzeyes
macavely
Joined Nov 4, '02
if the tire wire on more on the inside or outside tired that has to do whit the camber, and if the car turn more to one side then the other. hope that helps
post May 12, 2003 - 2:05 AM
Mynzeyes
QUOTE (macavely @ May 12, 2003 - 12:18 AM)
BEAT YOU! heheheh. :-p
AIM==Mynzeyes
post May 12, 2003 - 11:40 PM
Junior
Joined May 5, '03
From Toronto
If your car is not lowered and you are getting uneven wear, get your wheels alligned and balanced.
Lo-Fi Version Time is now: November 27th, 2024 - 4:17 PM
