might get good deal on 3s swap, is this all the parts? |
Nov 18, 2005 - 3:04 AM |
Enthusiast Joined Nov 6, '04 Currently Offline Reputation: 0 (0%) |
the swap includes Engine
Transmission 5-Speed AWD ECU Complete Harness Turbo Intercooler Distributor Alternatur Starter A/C Compressor Power Steering Pump Intake Manifold Exhaust Manifold All Sensors Clutch Fly Wheel Pressure Plate correct me if im wrong, but this is just about everything needed to swap right? if this is everything, and the motor checks out ok when i go to take a look at it, i might swap instead of 5sfte. |
Nov 18, 2005 - 3:10 AM |
nope, you are missing vital stuff that will make your car not run. buying these motor/tranny combo deals is not a good idea for a swap. always BUY A CLIP. these combo things are only good if you already have an alltrac or turbo mr2, and you just need the basic motor because your car has everything else.
Nov 18, 2005 - 7:55 AM |
QUOTE(lagos @ Nov 18, 2005 - 3:10 AM) [snapback]356925[/snapback] nope, you are missing vital stuff that will make your car not run. buying these motor/tranny combo deals is not a good idea for a swap. always BUY A CLIP. these combo things are only good if you already have an alltrac or turbo mr2, and you just need the basic motor because your car has everything else. agreed ESPECIALLY if you dont know EVERY little peice thats needed. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Nov 18, 2005 - 8:10 AM |
The tranny and clutch setup is useless to you also.
Art you need a sig that says " No its not good enough, buy a clip." -------------------- |
Nov 18, 2005 - 11:24 AM |
thanks guys. thought it was too good to be true.
Lo-Fi Version | Time is now: January 12th, 2025 - 2:51 AM |
