awd st204?, at200? |
Nov 18, 2005 - 8:08 AM |
Enthusiast Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) |
well i was thinking the other day on how maybe itd be possible to convert our fwd into awd????? maybe getting a 3sgte and using it's tranny and convert it to awd with its transfer case and all components in the rear from a junked up gt-four.......or a st185 if it fits????? woiuld it be possible if parts were availiable??? would the at200 be able to aswell as the st204?
Nov 18, 2005 - 8:11 AM |
Yeah its been done.
Yeah you need basically a rear ST205 clip. Yeah you need basically a front ST185/ST205 clip. 2 clips = a car. Go buy a car thats already turbo AWD already. -------------------- |
Nov 18, 2005 - 9:01 AM |
this has been covered like 600 times.....go to general discussion...someone is doing it right now
Nov 18, 2005 - 9:37 AM |
kooooool
Nov 18, 2005 - 6:50 PM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
You'll also need space underneath for the driveshaft
Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 19, 2005 - 3:38 AM |
QUOTE(GT4WRC @ Nov 18, 2005 - 6:50 PM) [snapback]357139[/snapback] You'll also need space underneath for the driveshaft There is space. I'd like to do it some day. Like Supersprynt said, all you need is a front st185 or st205 front, and a st205 rear. Not really simple, but very possable. -------------------- Live Free, Be Happy
Nov 19, 2005 - 12:22 PM |
Enthusiast Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
too much work for my opinion.
-------------------- PROJECT 6TH GEN
<FS: Things up for grabs> <Progress> |
Nov 19, 2005 - 1:08 PM |
QUOTE(Bigmeanbulldog55 @ Nov 19, 2005 - 3:38 AM) [snapback]357232[/snapback] QUOTE(GT4WRC @ Nov 18, 2005 - 6:50 PM) [snapback]357139[/snapback] You'll also need space underneath for the driveshaft There is space. I'd like to do it some day. Like Supersprynt said, all you need is a front st185 or st205 front, and a st205 rear. Not really simple, but very possable. those are the parts you need. thats the easy part. then you have to cut, weld, and fabricate mounting brackets for the whole rear end. trust me, its not something the tipical swaper can or should be doing. when i did my swap i had the driveshaft and the whole rear diff from an st185 (same as the 205) and its not just something that bolts on. GT4WRC, yes we have a chanel forn the driveshaft. the whole front half of our cars are basically the same, its just the rear end that needs modification This post has been edited by lagos: Nov 19, 2005 - 1:09 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Nov 19, 2005 - 5:43 PM |
Enthusiast Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) |
QUOTE(Shigexile @ Nov 19, 2005 - 10:22 AM) [snapback]357300[/snapback] too much work for my opinion. exactly, unless your a diehard 6gc enthusiast, theres a lot better alternatives for the money you would spend. -------------------- I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Nov 21, 2005 - 4:59 AM |
Enthusiast Joined Jan 29, '04 From Brooklyn moved to Miramar Florida Currently Offline Reputation: 2 (100%) |
you should of bought the one that was done a year ago it was on E-bay $12'000 if you want to buy it I can call that guy...
He can proable get it done for you . |
Lo-Fi Version | Time is now: January 12th, 2025 - 9:51 PM |
