> Engine burning oil
post Nov 18, 2005 - 2:25 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
just a quick question... if when you turn on ur car there is a small puff of blue smoke this means it is burning oil correct?
so um.. this means oil is leaking right? is it a cheap fix? how would you fix it?
06 Civic EX
My For Sale Thread
post Nov 18, 2005 - 2:46 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I'm no engine specialist, but that might be from the oil getting past the piston rings(I think thats what they're called) and into the combustion chamber. It generally goes away after they have soaked up oil to create that better seal. To fix it, you need to replace the rings and possibly other things?
But someone who is more of an expert can correct me, or maybe i'm right.
This post has been edited by 95CelicaST: Nov 18, 2005 - 2:54 PM
**** Photobucket
post Nov 18, 2005 - 3:38 PM
QUOTE(elvasoshexai @ Nov 18, 2005 - 2:25 PM) [snapback]357062[/snapback]
if the smoke is BLUE during cold starts, its most likely valve seals.
post Nov 18, 2005 - 6:02 PM
elvasoshexai
Joined May 16, '05
yea. it's a tint of blue when it starts up. goes away after like 1sec... are there other types of colours it could be or sumthin?
hm. so valve seals are something you gotta replace when you remove the valv cover right? and it's not a normal thing they replace during timing belt changes when they replace seals and stuff right?
This post has been edited by elvasoshexai: Nov 18, 2005 - 6:04 PM
06 Civic EX
My For Sale Thread
Lo-Fi Version Time is now: January 16th, 2025 - 1:08 AM
