> oil in spark plug chamber?
post Nov 19, 2005 - 11:14 PM
Irishflame27
Joined Sep 3, '04
From Avondale, AZ
i have a 5sfe, and i pulled the spark plug wire out of the head and oil came out as well, i know there is a bad seal but what should i change the valve cover gasket or the head gasket??
post Nov 19, 2005 - 11:19 PM
just get a new valve cover gasket... very easy fix
post Nov 20, 2005 - 10:20 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Make sure you get a VCG and tube seals. Don't let em screw ya!
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Nov 20, 2005 - 10:33 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
this seems to be a common problem. This happened to me a couple weeks ago. i replaced the gaskets under the valve cover bolts (sorry dont know what it was called exactly), and it fixed my problems. Just to make sure, i also replaced the spark plugs and spark plug boots+wires. Cheap cheap, about a half hours work. have fun.
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Nov 21, 2005 - 12:44 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
hmmm, maybe this relates somehow to my problems(see other topic) I looked at one of my spark plugs in the engine and it looked like it had oil or something on it.
Lo-Fi Version Time is now: January 17th, 2025 - 1:05 AM
