> vibration when turning
post Nov 22, 2005 - 7:41 PM
markie
Joined Aug 6, '05
From cerritos, california
so if you all dont know i recently got into an accident, where i hydroplaned and slammed into a wall. 750 dollars later, i get my car back and i notice that my car vibrates significantly when turning left (increasing in vibration the faster i am going) but doesnt vibrate at all when turning right. im speculating that it may be the tire rubbing with the inner fender plastic, but i was wondering if it could be anything else.
things happen for a reason.
post Nov 23, 2005 - 12:31 AM
Jaws4God
Joined Mar 27, '04
Well i'm sure you'd hear it rubbing the plastic... cuz when I installed my cold air intake it pushed the fender plastic into the tire on tight turns... it made a loud buzzing sound and it wore the plastic away very quick... so just take a look and you can see if it is...
post Nov 23, 2005 - 2:03 AM
check to see if your A arm is bent.
post Nov 23, 2005 - 2:44 AM
macavely
Joined Nov 4, '02
what batman said.. also check to see if you right strut is blow ... and make sure axle doesn engage when you turn the wheel....
post Nov 23, 2005 - 4:44 AM
Hanyo
Joined Aug 16, '03
From Bay area
the simplest solution are the best.
try the easy stuff first.
like rotation your rims and then try the right turn agian. this will elimate a bent rim.
then you can inspect and measure the a-arms and what not.
good luck.
Lo-Fi Version Time is now: December 12th, 2024 - 1:31 PM
