> question on the install KONI AND GC, Koni cartridges and GC coilovers
post Nov 23, 2005 - 4:37 AM
pnoywitmustrdsau...
Joined Mar 28, '05
From California
i did the install of both the replacement of the stock shock cartridge with the koni yellows, and also the conversion of the stock spring to GC coilover setup, i'm pretty low considering the fact i gave some room for bounce and rebound of the shock. But the thing that is really getting me that its doing everything that its suppose to do (you know tighter turns and corner and keeping my tires to the ground). BUT THERE IS SQEAKING EVERY TIME I TURN THE WHEEL. i did what the instructions said. but i see in the installer guide here on the forum, that they did not put the upper perch part( the one that held the existing stock spring) instead its the coil, then top perch, then the bearing assembly then the top that contains the three screw heads in??? so the perch for the stock spring is not needed anymore??? give me back some infomation so i can end or at least solve the SQEAKING noise in the front suspension!!!! thanks in advance to whom ever helps out.
Lo-Fi Version Time is now: December 12th, 2024 - 11:51 AM
