2 Pages V  < 1 2
> hellpp please, engine turns off by itself
post Dec 25, 2005 - 8:56 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Not 100%, I know it will trigger a CEL light. I know if the MAF sensor is even slightly off on a 3sge it really screws up the motor.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Dec 26, 2005 - 6:06 AM
immortal
Joined Aug 21, '05
From Cyprus
what is the MAF sensor my friend???
its a seperate sensor from the air flow meter or is the same?
post Dec 27, 2005 - 8:37 PM
Agent21
Joined Sep 12, '05
Well it is the mass air flow sensor. I am pretty sure your engine has a mass air pressure (MAP) sensor. I was just drawing the conclusion that if the mass air flow inpacts the race car much like the symptoms you describe it is possible the air temp sensor is doing the same. Or maybe the MAP sensor. If your friend has an air temp sensor you can use to test, I would do that first and see what happens.
94 GT Liftback
post Dec 27, 2005 - 9:29 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
a new idle air control valve is 160-220
post Dec 27, 2005 - 9:33 PM
LewFX
Joined Jan 28, '05
hope this helps
PDF of AIC
This post has been edited by LewFX: Dec 27, 2005 - 9:37 PM
post Dec 28, 2005 - 8:23 AM
immortal
Joined Aug 21, '05
From Cyprus
basically i have a code LewFX
P0110 Intake Air Temperature Circuit
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 24th, 2024 - 6:05 AM
