GT4 fuel pump replacement/upgrade guide...., Gen 6 (and possible Gen 5) |
Nov 26, 2005 - 3:39 AM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Disconnect battery and ensure no naked flames our sources of ignition are close by. Wise to have a decent sized fire extinguisher on hand too.
Inside the boot, remove the metal access panel and white plastic conduit cover and disconnect the two multiplugs. Remove fuel filler / inner arch guard.. ... then remove the fuel tank cover. 6 bolts and one panel clip IIRC. The removed cover. Which allows full access to the tank... Remove the 4 screws holding the filler flap in place.... .... and simply carefully pull the assembly to one side. Filler tube is not secured anywhere else so no more clamps etc to worry about there... Next, remove hose clamps on the return and breather pipes and remove hoses (have a container ready to catch and fuel which may leak out)... You can then undo the fuel feed pipe at the union shown below... With something below the tank to take the weight when it's freed, undo the nuts on the two 'straps', holding the tank in place... ... and lower the tank down... The fuel tank in all its glory... ... and the 'hole' left behind... Fuel level sender unit is below the panel closest with the fuel pump 'above'. Clean the area surrounding the panel to ensure debris etc doesn't fall inside the tank and remove the securing bolts... The OE fuel pump... The replacement pump. A 255 l/hr Walbro high flow pump rated to 500bhp. The uprated pump in place. I decided to solder and heatshrink the new +ve and -ve wires in place rather than using the supplied crimps.... Fitment is simply the reverse of above. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 26, 2005 - 3:47 AM |
great post. only usefull for alltrac/gt4 guys tho. us GT/ST guys just have to lift the back seat for easy access to the pump.
Nov 26, 2005 - 4:04 AM |
Enthusiast Joined Mar 30, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
Great How-to photo article
Nov 28, 2005 - 5:43 PM |
Enthusiast Joined Nov 27, '05 From Vienna, Austria Currently Offline Reputation: 0 (0%) |
Why not just remove the carpet on the trunk and change it from there?
-------------------- cya, abraxxa
Nov 29, 2005 - 12:27 AM |
QUOTE(abraxxa @ Nov 28, 2005 - 5:43 PM) [snapback]360653[/snapback] Why not just remove the carpet on the trunk and change it from there? Because the fuel tank is right at the rear of the car, not under the back seats. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 29, 2005 - 9:14 AM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Are you sure you have to take out the fuel tank to change the pump?
From the one pic it looks like there is a hole in the trunk that corresponds to the top of the fuel tank, where the fuel pump is. I think if you pull the carpet out of the hatch you could have changed it that way. |
Nov 29, 2005 - 9:47 AM |
Enthusiast Joined Jun 14, '05 From colorado Currently Offline Reputation: 0 (0%) |
QUOTE(abraxxa @ Nov 28, 2005 - 5:43 PM) [snapback]360653[/snapback] Why not just remove the carpet on the trunk and change it from there? yep it looks like there is a service hole in one of those pics -------------------- |
Nov 29, 2005 - 11:57 PM |
Thanks for your vote of confidence everyone. I guess that not having an ST205 GT-Four anywhere near, you are unable to speak with any authority on this matter No one in their right mind would do all of the above if it was just a simple task of removing four screws and an access panel
FYI, that panel only allows you to remove the fuel level sender unit. The only way to swap the pump is by removing the tank - end of story. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Nov 30, 2005 - 6:47 AM |
Enthusiast Joined Mar 25, '04 From Germany Currently Offline Reputation: 0 (0%) |
gary is absolutely right! tank has to be removed to reach the pump
thanks for the documentation, gary! that is something i want to do in the near future. do you think the walbro pump is the best choice (i know everybody seems to use them)? i have heard it has a shorter lifespan than the stock pump!? |
Nov 30, 2005 - 12:33 PM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
QUOTE(GT4WRC @ Nov 30, 2005 - 4:57 AM) [snapback]361459[/snapback] The only way to swap the pump is by removing the tank - end of story. Gary Unfortunately it is the only way. There is another option though, if your pump is OK and your only doing this to "Upgrade" then fit a swirl pot which is fed by the standard pump, as it dosnt need to create pressure for this job it can pump at a far greater rate than normal. Then have a remote "Race" pump fed by the swirlpot, supplying the feed and pressure to the fuel rail. |
Nov 30, 2005 - 2:03 PM |
QUOTE(djr97 @ Nov 30, 2005 - 6:47 AM) [snapback]361542[/snapback] i have heard it has a shorter lifespan than the stock pump!? That's news to me. Sounds like one of those urban myths TBH, a swirl pot would be a lot of extra work for no real gain on a road car. Much easier to drop the tank. Race car is a different though. Exactly what I've done on my rally car... A low pressure Holley pump feeds the swirl pot while a high pressure Walbro feeds the motor. Should hopefully eliminate any chance of fuel starvation by 100% Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Dec 3, 2005 - 1:25 AM |
Sweet so thats what the bottom of a GT4 looks like. I contacted this one guy on ebay who is selling an ST205 clip GT 4 with an AWD conversion. Its going for like $3-4K range. He said he'll throw in everything needed to make my 6G into a GT-4. If he knows as much as replacing the fuel tank to make it work, than I guess he knows his stuff.
Feb 6, 2006 - 1:34 PM |
Enthusiast Joined Sep 7, '05 From LISBON,PORTUGAL Currently Offline Reputation: 4 (100%) |
hi guys, i see you put walbro 255lhp fuel pump in celica st
my question is which? toyota supra or mr2 i dont no which thesse fit in celica st (7A-FTE) WALGSS341/400-760 91-95 Toyota MR2 87-92 Toyota Supra Turbo $99.95/ea WALGSS315/400-760 84-92 Toyota Supra NA $99.95/ea WALGSS342/400-765 94-98 Toyota Supra NA $99.95/ea WALGSS341/400-762 94-98 Toyota Supra TT $99.95/ea thi is the site i search: walbro 255lph fuel pump -------------------- |
Feb 6, 2006 - 2:31 PM |
QUOTE(celica3000 @ Feb 6, 2006 - 1:34 PM) [snapback]389657[/snapback] hi guys, i see you put walbro 255lhp fuel pump in celica st Nope, guide is to putting a fuel pump in a GT4 Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Feb 6, 2006 - 3:04 PM |
you'll need this one ( WALGSS341/400-762 94-98 Toyota Supra TT $99.95/ea) for the 7afte
Feb 8, 2006 - 1:38 PM |
thanks playr158 for the reply and information
Lo-Fi Version | Time is now: November 27th, 2024 - 1:19 AM |
