> car audio setup, wiring Q's
post Nov 26, 2005 - 3:05 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
hey, I'm going to be swapping out my front speakers for some 6.5"'s, powered by a small amp I'll be putting under one fo the front seats (probably passenger), then I will be running 1 10"sub in a box off of a seperate amp I'll have in the trunk. Now i have neevr worked on the audio setup in my celica or any other celica, So im wondering how much wire im going to need, I'm guessing one of these will do:
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK44
help me out!
Thanks,
Shawn
post Nov 26, 2005 - 4:44 PM
mikew04
Joined Feb 19, '04
From austin tx
If you have two amps, it will be easier to get two wiring kits. With that kit you most likely arent going to have enough power/ground cable depending on the route you take, and you only get one set of RCA's when you need two.
For a cleaner install, I would get a larger guage power cable run into the car off the battery, use a distribution block, then run the power cables to the amps.
Also, unless it is a fairly small amp (dimension wise) that you are putting under the front seats, you'll probably want it under the driver's seat; it has much more room. If you take out both seats you'll see what I mean.
Good luck
post Nov 28, 2005 - 4:22 AM
lilmancelica94
Joined Oct 7, '04
From Illinois
Hey Shawn. My name is Chris and I am a Circuit City Roadshop Installation Specialist. If I were you and wanting to do an amp install like what you're wanting Circuit City has a wiring kit that comes with everything and I mean EVERYTHING that you would need for a multiple amp install. I have the kit in my 94 Celica ST.
Here's the web address for the description of the kit:
http://www.circuitcity.com/ssm/Tsunami-Mul...roductDetail.do
This kit is perfect for what you need. Its also cheaper to get all of this in the kit than it is seperately.
I'm glad I was able to help an up and coming installer. If you have any questions just send me a PM and i will gladly answer any questions i can that you might have.
This post has been edited by lilmancelica94: Nov 28, 2005 - 4:25 AM
post Nov 28, 2005 - 6:52 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
I highly recomend that you take mikew04's advice about having one larger wire from the battery, splitting off at a distribution block. I remember walmarts sells a kit (made by scoch) w/ 4g wire splitting into two 8g from a distribution block. The kit was decent quality and pretty much had everything you needed for two amps. It was 39.99 (cnd)
This post has been edited by K-ESD: Nov 28, 2005 - 6:53 PM
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
post Nov 28, 2005 - 9:29 PM
Tech9ine
Joined Jun 28, '05
From MB, Canada
good advice, I'm going do the fatty off the battery and run the dist. block like you suggested, And I've got the 2 RCA cables, So I'm pretty much doing what mikew suggested (thanks by the way). Anyone have some suggestions for cleaner wire run to the trunk, other than under the carpet? i dont want any carpet lumps.
post Nov 29, 2005 - 10:09 PM
mikew04
Joined Feb 19, '04
From austin tx
Run the power wire from the engine bay into the dash, behind either kickpanel, under the door sill... you can follow the wires under the seat for that amp. The other cable can be continued behind the panel where the rear speakers are located and then run to the trunk.
RCA's can be run on the other side.
I have my RCA's running behind the dash, under the center console (following the shift linkages and airbag wiring) then under the seats where my amps are located.
If you decide to run RCA's under the door sills, make sure you run it on the side you are mounting the amp under the seat for ease of installation.
Lo-Fi Version Time is now: November 28th, 2024 - 4:47 AM
