> 4AGE SWAP
post Nov 28, 2005 - 9:42 PM
ekstasis
Joined Nov 25, '05
From los angeles
I decided on swapping out my 7afe w/a 4age silver top..maybe blacktop. are there any other additional parts that are needed that don't come with a ae101 levin front clip?
post Nov 29, 2005 - 12:09 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Not really.
The wiring harness needs to be done, of course. I can do it for you for $350. Including shipping back to you.
-Doc
This post has been edited by Dr_Tweak: Nov 29, 2005 - 1:13 AM
Click here to see my swaps
drtweak@phoenixtuning.com
post Nov 29, 2005 - 10:36 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
You will need a throttle cable if the one on your clip has been cut.
A celica GTS cable will work and will fit snuggly off of any model car. I used a 87 GTS cable for mine.
Plus, you need to swap all you 7A motor mounts with the 4age.
You will need to find a spot to mount the External igniter, coil, and that one small piece for the starter. <----can someone explain what this thing actually is? I know It can't be a fuse.
This post has been edited by soulshadow: Nov 29, 2005 - 10:39 AM
post Nov 30, 2005 - 12:10 AM
Dr_Tweak
Joined Mar 31, '04
QUOTE(soulshadow @ Nov 29, 2005 - 3:36 PM) [snapback]361102[/snapback]
A throttle cable from a 5th Gen Celica ST will also fit, along with any Tercel or Paseo.
What starter thing? Do you have a pic?
Lo-Fi Version Time is now: December 4th, 2024 - 5:54 AM
