235's on 7.5" rim? |
Nov 29, 2005 - 6:18 PM |
I am considering some Goodyear Eagle F1 GS-D3 in 235/40/17 and was wondering about fitment on a 7.5" rim. The specs on tirerack say a rim width range of 8-9.5". Anyone put oversize tires (width wise) on rims? What was your experience?
Nov 29, 2005 - 8:57 PM |
Enthusiast Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) |
Should work...I used to work at a tire shop and we would sometimes install some crazy sizes onto some rims. I don't think that .5" would make much of a difference if tirerack says the minimum is 8.0". But then again, I could be wrong.
Nov 29, 2005 - 9:09 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
QUOTE(Verde97 @ Nov 29, 2005 - 8:57 PM) [snapback]361382[/snapback] Should work...I used to work at a tire shop and we would sometimes install some crazy sizes onto some rims. I don't think that .5" would make much of a difference if tirerack says the minimum is 8.0". But then again, I could be wrong. i back that up to. Working at a tire store you do some crazy things like putting fat tires on skinny wheels. -------------------- |
Nov 30, 2005 - 1:30 AM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Do it. I love the idea of using wider tires such as that, its good protection for the rim and its wider meat which can't be bad at all.
I would also back up the previous two opinions.....I've seen some rediculously wide tire setups in person, and I think as long as they hold the bead it should be fine, which the 235's should do. I figure, 225's are done on 7" wide wheels often, and so a 235 on a 7.5" wide wheel should yield about the same results. Good luck. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Nov 30, 2005 - 9:51 AM |
235's would be fine on 7.5in rim...it will give a tad bit of wheel protection also. I ran 245's on 7in wide and that was alittle bulging
Nov 30, 2005 - 2:41 PM |
Thanks guys. I think I will go for it and will let you know how it works out.
Lo-Fi Version | Time is now: January 10th, 2025 - 3:04 AM |
