> Surging...
post Nov 30, 2005 - 10:28 PM
DmVinny
Joined Feb 23, '03
From Florida
Hey guys, I'm having a problem, I am experiencing surging when I drive, it seems like it's bogging, than it will try to pick up than bog down than after about 3 or 4 surges it's fine till next gear... I've changed my air filter, oil filter, distributor cap, and ignition coil today and it still seems to be happening... any suggestions?
post Nov 30, 2005 - 10:34 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
do you have cel light on? any vaccuum hoses broken?
post Nov 30, 2005 - 10:35 PM
DmVinny
Joined Feb 23, '03
From Florida
If you mean my engine light, no it's not... i check the vacuum hoses quickly but didnt notice any broken ones... I also changed out my pcv valve.
post Dec 1, 2005 - 2:12 AM
Dunners
Joined Oct 25, '05
From Brisbane, Australia
I reckon it might be you're spark plugs, the same thing was happening to me last year and after changing the plugs it was fine. In the mean time i found that if you hold down the accelerater to 3500 rpm for about 1 second before you take of it makes it not so bad. Hope it helps.
This post has been edited by Dunners: Dec 1, 2005 - 2:14 AM
post Dec 10, 2005 - 7:39 PM
TrD3sgte94
Joined Dec 4, '04
From just moved from houston to austin
same thing happened to mine last year and all i did was replace the sparkplug wires but you should definetaly check your plugs and make sure they are gapped while you have them out.
-wess-
[SIZE=7][COLOR=blue][SIZE=1]-WES-
post Dec 10, 2005 - 8:10 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
by surging u mean hesitate?
bboy
Lo-Fi Version Time is now: November 29th, 2024 - 9:20 PM
