> Fluid Sound, Gurgle Behind Dash
post Dec 1, 2005 - 2:47 PM
msmith777
Joined May 19, '05
I don't know what type of fluid I would have between the dash and firewall or near the firewall within the engine compartment, but I am hearing a gurgle/sloshing sound when I stop at stop signs or red lights then pull away. It seems like some container of fluid is only partially full and there is water or some other fluid sloshing during the car movement. I don't get the sound during highway speeds as the fluid doesn't seem to move around so much without changes in momentum. Any help would be greatly appreciated.
Washer fluid works fine.
'96 GT 5S-FE
84k
post Dec 1, 2005 - 3:23 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Either coolent from the heater or ac fluid. Which container seems empty?
post Dec 1, 2005 - 3:27 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
The only fluid that should be entering the passenger compartment is coolant. If there is a sweet smell when you turn on your heater or if your windows fog up when you initialy turn on the defroster you probably have a leaking heater core. The gurgling sound could be caused by air in the coolant system.
post Dec 1, 2005 - 4:04 PM
Chanh55
Joined Jun 29, '03
Hey I hear the same thing, but it's coming from the rear... I think. Maybe it's the gas tank?
post Dec 2, 2005 - 8:55 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Mine does the gurgling on start up but I recently replaced the radiator so that might be why.
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Dec 2, 2005 - 4:34 PM
shin
Joined Aug 21, '04
From New York City
if it's from the rear it might be the fuel pump.
~*MuH NeW RiDe*~
post Dec 2, 2005 - 4:57 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
i also get that noise coming from behind the dash
Lo-Fi Version Time is now: November 30th, 2024 - 10:54 PM
