Parking lights come on 70% when key is in "ON" position, Bad Relay? Crossed Wire? |
Dec 2, 2005 - 10:09 AM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
I finished installing my LEDs in my climate control and now when I turn the key to on, the parking lights come on 70%. I disconnected my LEDs in the climate control and the problem stayed. Everything else is normal.
The only problem I can think of is a bad relay, or more likely, somehow my cigarette lighter power got crossed with the cigarette lighter ring that turns on with the parking lights. I cut off the plug and connected my LEDs to it, but I didn't touch the actual lighter plug. No fuses have blown, or at least the "Turn" or "Hazard". Please let me know what I can do to solve this problem. Thanks, Alex Cutrara -------------------- |
Dec 3, 2005 - 5:20 PM |
Hmmm... This problem solved itself. It's not doing it anymore, I'll bump this topic if anything changes.
Dec 5, 2005 - 12:16 AM |
Enthusiast Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
Hey i didn't know that you could get LED's that small for your climate controls??? What size? and where did you find them at?
Dec 5, 2005 - 10:08 PM |
They're either 3mm or 5mm, I'm not sure, but I had to trim them down a bit. I got 50 on eBay for like $6. It requires a fair amount custom work. It took me 8 hours, 4 hours each on two days because I ran into a few problems. But to me, it's DEFINATELY worth it.
Lo-Fi Version | Time is now: November 29th, 2024 - 12:34 AM |
