WTB: Misc Swap parts, mtr. mount brackets, MSD 6a & coil, etc... |
Dec 4, 2005 - 6:18 AM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
I'm getting close to finish on the swap, wiring the ECU and trying to get the motor cleaned up have been a pain. Anyways I have a few parts I really need to pickup asap.
-5sfe Motor Mount brackets (timing side,front&rear tranny mounts, and the driver side tranny mount). *I need the brackets not the actual insulator piece* Also need the bolts but I can find those elsewhere if I need to. -MSD 6a Ignition & Blaster 2 coil -Gauge Pod (doesnt the supra MKIV pilar 2 gauge pod fit?) -5sfe Pwr. steering res. & high pressure line. I will add more items later but this is to just get me started -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Dec 4, 2005 - 8:31 AM |
And I need to figure out what to do about the throttle cable, do I need to pickup a GT throttle cable because mine doesnt look right? I have 2 but the longer one that looks like it could reach the gap between the end of the cable wrap and the end of the cable theres not enough room to wrap around the throttle thing. yes thing.. lol im so tired its not even funny.
anyways thanks for the info -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Dec 4, 2005 - 11:55 AM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
use the GT throttle cable, u need to make a bracket to extend the stock holder.
Dec 4, 2005 - 11:27 PM |
OK so I need to add a GT throttle cable to my list... will a 4th or 5th gen cable fit? I have a couple GT celicas in local junkyards just no 6th gen.
Dec 5, 2005 - 6:19 PM |
and bump again...
Lo-Fi Version | Time is now: November 23rd, 2024 - 1:46 PM |
