> Vacum Problem / thorttlebody leak, running at 1500 rmp
post Dec 6, 2005 - 1:29 AM
rev_limit
Joined Nov 7, '05
From Green Bay , Wisconsin
Can anybody help after i took off my throttle body to clean.. i also bore it a little with drill than i sand it made it smooth .. and then when i put it back together , my car is now running at 1500 rpm at normal temp.. i check for leaks but cant find any.. you guys think i need a new gasket or somthing....or did i mess it up by bore_ing the throttle body ...
i can use some help if you guys know what might the problem be...
i didnt grind anymetal off or near the butterfly..... i already check the cable...
This post has been edited by rev_limit: Dec 6, 2005 - 1:41 AM
post Dec 6, 2005 - 1:32 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
How exactly did you make it bigger ? Did you grind out any metal near the butterfly ? if there is any extra space in between the BF valve and the TB then That could raise your idle. Did you check the throttle cable ?
I will return one day.
post Dec 6, 2005 - 1:33 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
yea, I'd say you prolly ****ed it up by trying to bore it out.
post Dec 6, 2005 - 1:47 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
When you take off the throttle body, you should put a new gasket on. I don't know how you could bore it out without using a different butterfly.
Live Free, Be Happy
Lo-Fi Version Time is now: February 17th, 2025 - 1:19 PM
