2 Pages V  < 1 2
> Acceleration Lag?, *sigh*
post Dec 7, 2005 - 2:34 PM
Magic
Joined Mar 30, '03
From Cyprus
Any blinking from check engine bulb??
post Dec 7, 2005 - 3:40 PM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
Like said before could be vacuum leaking, or, as in my case brakes got stuck.
post Dec 7, 2005 - 4:30 PM
you know, i always hear people say ...fuel filter. yet ive never seen it fix anything for anyone.
jen, try to drive the car some more....pop the hood, and see if there are any more details you can give us. so far we have, stall, and low power. that could be anything from a clutch, vac line, to electrical . does the car idle fine? does anything change when u put it in gear? does your rpm climb high, but your car is slow to accelerate?
post Dec 7, 2005 - 5:25 PM
st_celica_killer
Joined Sep 23, '04
From fresno
i'm having the same thing with my car.. when i press the gass it stall!! and wont feel any power until 3500 and above!!! plus engine light comes on.& off.and engine shakes like crap!!!
post Dec 7, 2005 - 9:04 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE(lagos @ Dec 7, 2005 - 9:30 PM) [snapback]364504[/snapback]
I had the exact same thing to me, and fuel filter replacement fixed it for me.
post Dec 8, 2005 - 3:06 AM
_rz_
Joined Jul 20, '04
From Russia, Moscow
As someone already said - check your spark plugs.
Had the same problem on my SSI. Checked everything. Spent quite a bit of money on different stuff.
And then in the end found out that I had a cracked plug. I checked it before, just didn't notice it.
post Dec 8, 2005 - 10:52 AM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
I have money on a cracked plug. $10 says you pull em out and find nice little black lins going down the sides of atleast one of them!
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
post Dec 8, 2005 - 11:08 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
believe it or not, i test drove a Dodge Avenger when i was looking for a car. (when i got the celica) and it had the same issue....the block was cracked...or soemthing to that effect and it was getting antifreeze into the cylinders and it was wicked slow....id floor it and it would even go. (not saying tahts your problem...but id look into it if all else fails)
Kawi Love
post Dec 8, 2005 - 11:14 AM
nik
Joined Sep 30, '02
QUOTE(Rjb23 @ Dec 7, 2005 - 8:04 PM) [snapback]364589[/snapback]
i had a wierd idea and no power the filter was the original oem part and i was at 120k it fixed alot of problems for me
post Dec 8, 2005 - 12:06 PM
Hawkins Corp
Joined Oct 16, '05
From omaha,nebraska
I had the same problem, My rpm shot up but i wanst even going 25 then a big puff of White smoke came out of the exaust so i took it to my cousin (whos works at a dealership) and for some reason he replaced the radiator and it was fixed??? I still cant figure it out , but at least its fixed.Gave me a good deal on the radiator to got it at dealrship employuee price.
Any feed back on this anyone?
post Dec 8, 2005 - 12:57 PM
nik
Joined Sep 30, '02
jen go take it to toyota and pay them to do an inspection its only like 30-40 bucks unless you have someone close that can look at it that knows there stuff everyone one is saying it could be this or that but its hard to tell with out better detail or being there so thats my best advise to you
post Dec 9, 2005 - 1:34 AM
Jen
Joined Jul 14, '03
From Jacksonville, FL
It was the fuel filter. tongue.gif Twas original with the car at 150k. Thanks for the help!
YoungSurvival.Org
post Dec 9, 2005 - 11:23 AM
nik
Joined Sep 30, '02
QUOTE(Jen @ Dec 9, 2005 - 12:34 AM) [snapback]365179[/snapback]
smile.gif glad you got it fixed
post Dec 9, 2005 - 3:44 PM
haha well good. thats really the 1st time ive seen somone say the fitler cause them some type of issues.
post Jan 10, 2006 - 6:23 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Sorry to bring up an old topic BUT... I'm having the same problem, but after I had replaced my fuel filter nothing changes, reset my ECU, dumped in some 44k (fuel cleaner/additive) and it got a little better but it just goes right back to how it was performing when the problem first occured once its had time to run its course. I'm not sure if i should keep dumping in 44k untill it gets better or just give up and take it to a shop to have the injectors cleaned with a more industrial solvent?
Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..."
post Jan 10, 2006 - 7:32 PM
Agent21
Joined Sep 12, '05
Trust me if 44K didn't clean it.....nothing will. That stuff is wicked. I'd one again check the plugs and head gasket type stuff. You losing and fluid? How does the rotor and cap look etc?
94 GT Liftback
post Jan 14, 2006 - 10:14 PM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
Plugs still are good, wires are good, rotor and cap are still Good, coolant levels and oil are good, not even any atf is being consumed. I'm half tempted to just throw some injectors at it and see how it goes since when I did put in the 44k it got a little better for a little while.
Fred
post Jan 15, 2006 - 9:49 PM
Rjb23
Joined Feb 8, '04
From KY
Sea Foam it.
post Jan 15, 2006 - 10:08 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
mass air flow sensor (map) along with O2 Sensor - that was my problem -
post Jan 29, 2006 - 1:28 AM
FreddyTheOthaMea...
Joined Feb 8, '04
From Thornton, CO.
o2s were all around 100mv to 340mv(ish). anyone know how much resistance should be in the ignition coil?
Fred
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 26th, 2024 - 10:49 AM
