3 Pages V   1 2 3 >
> So Im rebuilding a beams motor...., Who wants to touch me. :P
post Dec 7, 2005 - 2:41 AM
roman
Joined Dec 7, '05
From AKL NZ
Hi folks.
A few of you guys here seem pretty interested in the beams motor.
Well I am rebuilding one at the moment.
I know quite a lot about these engines, as I have been researching for the last year or so, trying to find out information here and there.
I have the motor in bits at the moment, my hands are tied until I get my bottom end bearings.
So if you have any questions, or would like to see any pics etc, let me know. smile.gif
My motor has a port & polished head (Which was done by an unknown company in Japan) heat wrapped TOMs extractrors, Apexi intake, cusco paddle clutch, light weight cusco flywheel, balanced crank/rods/pistons/flywheel, and the cat has been replaced with a straight through pipe.
Hopefully it will make in the region of 210-220 flywheel hp, or about 180-185 hp at the wheels.
This post has been edited by roman: Dec 7, 2005 - 2:56 AM
post Dec 7, 2005 - 2:44 AM
roman
Joined Dec 7, '05
From AKL NZ
heres a pic looking inside the plenum.
note the factory velocity stacks.
A pic of the block. Look where the block bulges on the side closest to the camera, inbetween the 1st and second bores from the left... This is the oil gallery used to feed the VVTI mechanism
Crank caps
crank
crank2
picture of the head (Notice the cam angle sensor, down the left hand end of the intake cam (closest to the camera)
head pic 2
Note the solenoid or what ever on top of the head, near the RHS of the closest (intake) camshaft.
New piston
Here is a picture of the porting that has been done.
picutre of the porting
rods
valves
Here are some pics showing the VVTI mechanism.
Notice the oil feed holes on both the end of the camshaft, and inside the cam pulley. It uses oil pressure to rotate the camshaft relative to the pulley.
VVTI mechanism
Note the hole coming out the side of the cam shaft... There is one on the other side too.
VVTI mechanism
Note the corresponding oil gallery, on the inside of the cam pulley.
VVTI mechanism
And here's the car that it will be going into. (eventually!)
Its a 1990 JDM SW20, with the hard top, 5 speed, and gen 2 3sge powered.
It goes pretty well at the moment, as it is rather light. Its the bare basics model, pretty much.
So it should go pretty well with a fresh beams motor pushing it along.
Anyway, if there is anything that anyone would like to know, just let me know. smile.gif
This post has been edited by roman: Dec 7, 2005 - 2:55 AM
post Dec 7, 2005 - 3:14 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
wow, i like! i got the pleasure of seeing a beams motor inside an mr2 (matter o' fact there were 2 of 'em) few months back. these things fly. so so nice!
bboy
post Dec 7, 2005 - 3:19 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Wow, that's cool. I'm glad to see more of these being done. Hopefully they'll develop some real aftermarket support one of these days. Those rods look a little small for a built motor.
Live Free, Be Happy
post Dec 7, 2005 - 3:31 AM
roman
Joined Dec 7, '05
From AKL NZ
Yep, it should be a fun car at the end of it all.
I agree, the rods do look a little on the skinny side!
I had the pleasure of driving a 1999 beams powered SW20 a few months ago, that had only 20,000kms on the clock. woot.gif
It looked brand spanking new.
It was being sold, and I sweet talked my way into getting a ride/drive. smile.gif
I havent driven a celica with a beams motor, but Im sure they go well.
I've also driven a 4wd caldina GT, which has the 190hp automatic version of the beams engine.
It wasnt amazing, but it went bloody well for a 1400kg car with 4 wheel drive and A/T!
Quad throttles from the TRD Altezza motor bolt straight on to the redtop.
TRD Altezza cams wont work however, but rods and pistons will, apparently. But 13:1 compression ratio is a bit unreasonable for a street car IMO. smile.gif
post Dec 7, 2005 - 4:38 AM
soven
Joined Mar 14, '05
From Auckland,New Zealand
j/k . Looks good
post Dec 7, 2005 - 5:20 AM
_rz_
Joined Jul 20, '04
From Russia, Moscow
Love your car. Good luck on your project
post Dec 7, 2005 - 6:39 AM
roman
Joined Dec 7, '05
From AKL NZ
Thanks for the comments.
Its been a long time coming so far, and Ive still got a while to go yet.
But its all starting to come together now, hopefully it will be up and running early next year. smile.gif
post Dec 7, 2005 - 6:44 AM
roman
Joined Dec 7, '05
From AKL NZ
QUOTE(soven @ Dec 7, 2005 - 4:38 AM) [snapback]364333[/snapback]
j/k . Looks good
I'd put you in my will to get the motor if I die, but then you'd just kill me. tongue.gif
Yeah Ive spent a lot so far, Ive had the block over bored half a millimeter, the head completely stripped down and rebuilt. Brand new oversized pistons, rings, belts, gaskets, filters etc.
Parts arent cheap, and they have to come from Japan.
But on the plus side, it will be virtually a brand new motor when I'm done. smile.gif
Will hopefully be worth the stress/money/effort. smile.gif
post Dec 7, 2005 - 7:13 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I would love to have one of these baby,
Good luck with the project.
6GC 4 Life Baby!!!
post Dec 7, 2005 - 2:51 PM
Magic
Joined Mar 30, '03
From Cyprus
Interesting Project!!!
Any idea about the pistons brand and size?About the rods brand?
Do you planning using ECU?
We have many projects in Cyprus with VVT-i Beams engine!!
I v seen 195 whp without touching engines internals so you should expect something more than 185whp! smile.gif
post Dec 7, 2005 - 3:12 PM
roman
Joined Dec 7, '05
From AKL NZ
Wow, 195whp?! Do you know what mods were done?
I say 185whp, because I want to be realistic about the gains. A lot of people think "Sweet, 15hp with a pod filter on"
I think 180hp at the wheels should be the minimum, and I'd be happy with that. Any more, and I'd be really happy.
Im interested in talking to any other beams owners, about mods etc.
Has anyone dynoed their beams motor before?
I am using standard rods and pistons, everything will be standard for now, except for what is listed.
I have a set of quad throttles from a silvertop 4age, that I will possibly adapt to the motor a bit later on.... probably at the same time as an ECU upgrade, and a cam grind or replacement cams.
I know of a blacktop 3sge in Australia, that is making 270hp at the wheels!
This post has been edited by roman: Dec 7, 2005 - 3:14 PM
post Dec 7, 2005 - 4:36 PM
Magic
Joined Mar 30, '03
From Cyprus
Yes!!!Actually i v been in the dyno day that a VVT-i had 197whp!!
Mods for the specific one was...(as fas as i remember)
AEM Air filter
E-Manage ECU
Kakimoto Exaust
maikl had 187whp running on many mods,check out his profile for the mods he is using.
http://www.6gc.net/index.php?action=members&itu=1026
A friend of me he is building his Celica ST202 VVT-i Beams for turbo using Turbonetics Turbine!!He will be on the road very soon!!
About the cams i think you should go with custom,i dont know a company that is making cams for that engine frown.gif
If you are interested in ECU have a look on the Brashboy website,if you send them an email they will reply to you after few days cuz of translation problem,they selling Power FC for ST202 VVT-i beams!
www.brashboy.net
For blacktop vvti you can find many products,even a complete modify engine block as i remember from TRD!!
post Dec 7, 2005 - 5:18 PM
roman
Joined Dec 7, '05
From AKL NZ
Awesome! I didnt know that there was a powerFC for the redtop engine.
That will probably be one of my next purchases, when Ive got the cash.
post Dec 7, 2005 - 5:26 PM
roman
Joined Dec 7, '05
From AKL NZ
P.S. If anyone has ICQ and would like to discuss redtops etc, my ICQ# is 823-6667. smile.gif
post Dec 7, 2005 - 5:33 PM
jdg371
Joined Jun 14, '05
that looks awesome.. and 187wph from it is awesome, props to maikl
we need to have more of this type of swaps.. maybe I should just keep my 5G and swap this bad boy in there hehehe
post Dec 7, 2005 - 7:01 PM
roman
Joined Dec 7, '05
From AKL NZ
Hopefully mine will turn out somewhere close to that.
post Dec 7, 2005 - 8:38 PM
ILuvMyCelica95
Joined Dec 16, '02
oooooh wow this thread is awesome!
post Dec 7, 2005 - 8:54 PM
celicaST
Joined Jun 23, '05
QUOTE(ILuvMyCelica95 @ Dec 7, 2005 - 6:38 PM) [snapback]364578[/snapback]
ya it is smile.gif its going to get huge in a hurry. that mr2 is so clean, thats going to be so fun to drive when its finished!
post Dec 7, 2005 - 9:17 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
These BEAMS motors looks like an absolute blast....I love the sound and power delivery of a high revving N/A motor just as much if not more than i like turbo. smile.gif
Good luck with the build, i want to see some videos of that in action when its all done. wink.gif
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: February 21st, 2025 - 5:26 PM
