> FS: 3rd gen 3SGTE head, ST205 - nearly complete (cams, injectors, manifold, TB)
post Dec 8, 2005 - 3:54 PM
scothaniel
Joined May 1, '03
From Michigan
After finding a hole in my forged pistons, I've decided to buy another stock motor and bring the car back to its original form. But before finding the hole, I had the engine shop rebuild the head. There was nothing wrong with it before, but since I had already pulled the motor 3 times I didnt want to risk pulling it again.
So, I have a 3rd gen ST205 head, all new seals and gaskets, fresh valve job, and deck surface skimmed and checked for straightness. Stock cams and gears, Intake manifold, throttle body, distributor, water outlet, fuel rail and injectors - all from the ST205. Injectors have been cleaned and balanced. Water elbow does not have sensor, but I may have a set laying around. TPS and ISC are present. I think I have the upper timing belt cover, but it might be cracked.
The only part I dont have at this time is the exhaust manifold, which had been modified for my the turbo kit - which also may be for sale if I dont use it on my wifes Celica.
Everything is at the shop right now, I'll go down and take pics later today.
Make offer.
Scott
West Michigan
Lo-Fi Version Time is now: November 30th, 2024 - 2:39 PM
