> emergency brake light
post Dec 8, 2005 - 5:56 PM
celi_gt_racer
Joined Feb 6, '03
From huntingdon tennessee
I'm a little confused.... it use to be that my e-brake light on the gauges only came on when my ebrake was set. As of recently - every time i brake hard - my ebrake light comes on in the cluster.... without the e-brake engaged. This is confusing the crap outta me... i thought it might be some signal to change brake fluid or something - anyone else have this problem before? kindasad.gif
post Dec 8, 2005 - 6:24 PM
that light comes on for 2 reasons. 1 is the ebrake and 2 is to tell you your brake fluid is low.
pop the hood and take a look at the brake fluid level. if it is low, get the car checked out to find the source of the leak. normally brake fluid should never go low on its own, and it it totally leaks out, you will have no brakes at all.
post Dec 10, 2005 - 5:06 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The fact it comes on during hard braking suggests it's the fluid, since it would slosh around.
If your fluid is full and the bobber to which the sensor is attached moves freely, the sensor on your actual e-brake handle may be loose.
post Dec 11, 2005 - 3:44 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Actually if your leaking pressure from the vaccum hose to the brake cylinder, it does that too. In other words, if there is a leak in pressure the brake comes on too. My car did that the other day and you can hear the vaccum sucking up air as the car was rolling. It scared the crap outta me too, cause I just finished installing some Subs and Amp, but make sure that you got lots of fluids and your hoses are not damaged.
post Dec 11, 2005 - 10:21 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
also check your brake pads.
post Dec 11, 2005 - 1:56 PM
Kplaya05
Joined Nov 21, '05
From Nevada, TX
Its the Brake Pads, thats exactly what happened to me and then it just stayed on just about all the time so i changed my pads and it whent off
post Dec 11, 2005 - 2:29 PM
celi_gt_racer
Joined Feb 6, '03
Thanks for all the suggestions guys.... i've got to get to checkin all that stuff..... lol biggrin.gif
post Dec 17, 2005 - 9:05 PM
celi_gt_racer
Joined Feb 6, '03
I've officially got my problem fixed..... my pads were almost non-existent
i was also fairly low on brake fluid - fixed both of those problems and now she's back to driving like a dream..... well sort of (besides the fact that it's still slow as poo) smile.gif
Lo-Fi Version Time is now: January 12th, 2025 - 12:23 AM
