7afe head/block |
7afe head/block |
Dec 10, 2005 - 5:04 PM |
Enthusiast Joined Dec 4, '04 From just moved from houston to austin Currently Offline Reputation: 0 (0%) |
i just pulled all kinds of parts out of my st and now i cant seem to find out how to get the head off. everything is disassembled off of the head, do i need to take off the camshaft and take out the bolts underneath? any help will be much appreciated...
-wess- -------------------- [SIZE=7][COLOR=blue][SIZE=1]-WES-
Dec 10, 2005 - 6:02 PM |
did you remove the timing belt?
13.6@108MPH, 5SFTE Powered |
Dec 10, 2005 - 6:13 PM |
You need to remove timing belt, remove cam caps, remove cams, then remove head bolts (located under camshafts)...
-------------------- "It's ok to be naked girl... I'm an artist!"
Dec 10, 2005 - 6:59 PM |
yes i pulled the timing belt off it was like the first thing i did and now i have pulled the caps and camshaft's off i just now can find a 12point 10mm socket to fit the headbolts underneath the camshafts. thanks for the help guys
Dec 11, 2005 - 3:38 AM |
Could somebody point me to the direction in how to remove the crankpulley the poor way, cause I can't find the tool needed to remove it.
Dec 11, 2005 - 10:00 AM |
QUOTE(soulshadow @ Dec 11, 2005 - 3:38 AM) [snapback]365776[/snapback] Could somebody point me to the direction in how to remove the crankpulley the poor way, cause I can't find the tool needed to remove it. when i did my first, it was outta the bay, and i used a long breaker bar, and hit it with a hammer, REALLY hard..so that the engine wouldnt rotate, but the bolt loosened. that was on a '98 motor, tho. every time since, ive had to use an air gun. -------------------- Former Team 5SFTE pro member ;)
Dec 11, 2005 - 7:37 PM |
i didnt even get around to taking it out today because i was trying to figure out why my 94 eclipse wasnt idling right...
Lo-Fi Version | Time is now: January 12th, 2025 - 12:38 AM |
