> 4agze
post Dec 10, 2005 - 5:35 PM
TrD3sgte94
Joined Dec 4, '04
From just moved from houston to austin
who knows where i could find one other than a junkyard, any part dealers ?
btw i only need the head not the whole thing
[SIZE=7][COLOR=blue][SIZE=1]-WES-
post Dec 10, 2005 - 6:14 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I have a 4AG smallport head without manifolds... make an offer (note... expect shipping to be around 25.00-40.00)
*Edit*
I just read your other post and looked at your profile. I reccomend you do some SERIOUS research before you try to buy parts. The mod you're suggesting (7AGE i'm gonna guess) is NOT easy to do and will require significant wiring changes. Even experienced mechanics can struggle with this hybrid conversion first time around. Do your research if you're serious...
This post has been edited by Kwanza26: Dec 10, 2005 - 6:17 PM
post Dec 10, 2005 - 7:09 PM
TrD3sgte94
Joined Dec 4, '04
i know its gonna be hard but i think i can get it done. i just want to buy one and then figure out what im going to have to do. i would make an offer but i dont know how much these things usually go for so let me look around for a little bit and ill get back with you kwanza. apreciate the help.
-wess-
post Dec 10, 2005 - 7:14 PM
trust what kwanza said. you really want to do all your research 1st before you buy anything when doing any kind of custom project like that. if you dont, youll end up spending money on stuff you dont need, or getting stuck half way through.
post Dec 10, 2005 - 7:35 PM
TrD3sgte94
Joined Dec 4, '04
ok i've read about it on this site but what other sites could be used as good reference to how to build the 4agze and maby info on what i might need.
post Dec 10, 2005 - 8:40 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
club4ag.com
post Dec 11, 2005 - 3:29 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
My suggestions is that you can dive straight in and figure out everything you need for the conversion or swap when your actually doing it, but you will end up needing a whole EMS to run the 7age. Unless, you plan to just swap in a 4agze engine.
Lo-Fi Version Time is now: January 12th, 2025 - 4:19 AM
