> gas mark
post Dec 11, 2005 - 7:40 PM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
Is my car the only one that marks quarter tank when on empty??
My car has died several times when on the quarter tank mark, and wanted to know if its normal for our celicas, or if its something wrong with mine.
post Dec 11, 2005 - 8:22 PM
do u have any overlay gauges installed?
post Dec 11, 2005 - 8:33 PM
celicaGT96
Joined Aug 14, '05
Are you talking about the aftermarket gauges, because the ones I have are the originals
post Dec 11, 2005 - 8:35 PM
celicarus
Joined Jul 5, '05
From Arlington, TX
that would make sense lagos since - the needle might be getting stuck at that point and won't go down any lower - or the over lay may not be positioned properly making him think its not empty yet - but normally if the yellow light comes on - don't drive more than 20 miles other wise ur risking it dude
could it be the fuel pump?
post Dec 11, 2005 - 9:08 PM
celicaGT96
Joined Aug 14, '05
well, when its full it marks exactly on the full line...
post Dec 11, 2005 - 9:26 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
i'd say chances are that you're car actually has 1/4 tank, but that where the gas is actually pulled from the tank is off.... That nshould be the problem I believe
post Dec 11, 2005 - 9:34 PM
celicaST
Joined Jun 23, '05
QUOTE(celicaGT96 @ Dec 11, 2005 - 7:08 PM) [snapback]365995[/snapback]
when i fill mine all the way, it goes above the full line and doesnt get down to it until after 20 miles or so. ive driven mine to where the needle drops below quarter so its not a common celica issue.
^what? im confused, if he had a quarter tank left why would his car be dieing?
post Dec 11, 2005 - 10:30 PM
dustin15brown
Joined Aug 17, '03
because the fuel is not gettin out of the tank... fuel pump. etc. i could be wrong though
post Dec 11, 2005 - 11:20 PM
there is a little wire with a plastic floater thing that is attached to the fuel pump assembly. this is what measures how much gas you have. i cant really see that thing broken, but anything is possible.
i would take your gauge cluster out and make sure the needle can move freely . push it all the way down with your hand and start the car up ...then see if it climbs back up nice and smoothly
post Dec 12, 2005 - 3:25 AM
_rz_
Joined Jul 20, '04
From Russia, Moscow
I'be driven my SSI till the needle droped below zero mark, and it still had about 5 liters left. So theres probably something wrong with yours.
And does the low fuel lamp turn on?
post Dec 12, 2005 - 3:34 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Celica has a 15 gallon tank, the light comes on when there's three miles left, the GT gets about 23-25mpg, and the ST gets 27-31mpg. Fill the tank all the way and mark your milage. My dad doesn't have fuel gauges on either of his trucks and that's how he measures it. That should also be enough info to test to see if it's the pump or the gauge. If it runs out and takes 15 gallon, it's the gauge. If it takes less, like 10-12, then you have a delivery problem.
Live Free, Be Happy
post Dec 12, 2005 - 6:52 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The little floating thing in the tank is called the fuel sending unit... and they do go bad or get knocked out of adjustment every now and again (especially on Fords for some reason)... You can either try to tweak yours a bit or simply replace it. Another cause could also be the cluster...
post Dec 12, 2005 - 8:06 PM
dustin15brown
Joined Aug 17, '03
QUOTE(Bigmeanbulldog55 @ Dec 12, 2005 - 8:34 AM) [snapback]366150[/snapback]
You mean three gallons.. correct
post Dec 12, 2005 - 8:32 PM
Hanyo
Joined Aug 16, '03
From Bay area
my car did the same thing. the needle would not go past the 1/4 mark.
My mechanic fixed it for me for free.
Lo-Fi Version Time is now: January 12th, 2025 - 12:16 AM
