> getting 3sgte, want 350+hp
post Dec 14, 2005 - 2:42 AM
dans_st
Joined May 24, '03
From Andrews TX
I am purchasing a st185 RC 3SGTE that I am going to pick up in Jan., Basically what can I do to reach 350hp with under $2,000?
I already have a upgraded fuel system, boost controller, and am about to purchase a Greddy E-manage ULTIMATE, I plan on using everything that is on car as I can on my new setup.
I have already recieved another GT32 turbo that I plan on using on the 3S
So basically what can I do to get around 350HP and is my budget high enough to do so?
here is a list on my engines mods. I know ALOT of the parts I won't be able to use but what do i need to reach my goal?
Thanks for all your help guys...
Performance Modifications
ITS GT32 turbo
3.5" downpipe
HKS SSQV blow-off valve
HKS 65mm BOV flange
2.5" intercooler piping
Apexi SAFC-II version 2
Turbo smart boost controller
Turbosmart 38mm wastegate
Autometer COBALT boost guage
Mishimoto 31"x11"x3" intercooler
KOYO Radiator
KOYO 1.3bar radiator cap
RC engineering 550cc injectors
Walbro 255lph fuel pump
Fuel pressure regulator
port & polish on head
port on intake & throttle body
intake manifold powder-coated black
valve cover powder-coated black
ZOOM clucth
INNOVATE LM-1 wideband O2 with datalogger
fast-turbo oilfilter relocation kit
Goodridge -6an fuel lines from tank
OBX fuel rail
Aeromotive in-line fuel filter
Aeromotive boost dependant fuel pressure regulator
magna flow exhaust
full 3.5" exhaust from manifold
(all Magnaflow 3.5" mandrel bends)
HKS filter
HKS catch-can
MSD sportcompact ignition plus
MSD custom fit 8.5mm wires
MSD Blaster SS coil
NX N-tercooler sprayer w/CF bottle
NX 35 SHOT w/RPM window switch
battery relocation to hatch
8ga. power wire to MSD and Walbro fuel pump
TRD short shifter
all new trans. cables,washers, bushings, ect...
If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
post Dec 14, 2005 - 5:02 AM
its gonna cost A HELL of alot more than 2k to make 350+whp on a 3sgte.
post Dec 14, 2005 - 7:23 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
What does it dyno at now? With a list of parts like that, you've got to have some higher hp numbers. 350hp is really up there. $2000 to invest really won't get you much of any thing. Maybe a nitrous kit will help. If you've got 250hp now, just add a 100 shot of nitrous. Nitruos is not really ever a good idea by the way.
Live Free, Be Happy
post Dec 14, 2005 - 10:35 AM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
cams would be a good start.
-Aaron-
post Dec 14, 2005 - 11:50 AM
dans_st
Joined May 24, '03
From Andrews TX
afroman Posted Today, 09:35 AM
-Aaron-
thanks I considered doing this, what kind of gain could this give me
presure2 Posted Today, 04:02 AM
I figured with the mods I have on the car already that that would already put me up in the 230-260hp range.
here is what I'm pretty sure I can use that I already have
ITS GT32 turbo
3.5" downpipe
HKS 65mm BOV flange
Apexi SAFC-II version 2 (have right now- ordered E-manage ultimate yesterday)
KOYO Radiator
RC engineering 550cc injectors ( plan on getting larger RC injectors)
magna flow exhaust
HKS filter
HKS catch-can
MSD Blaster SS coil
TRD short shifter
all of this will be on the car , I don't know which turbo manifold I am going to go with probably a equal lenght stainless steel manifold to use with GT32-this is not included in my $2000 budget
post Dec 14, 2005 - 12:15 PM
jgreening
Joined Jan 17, '04
From Illinois
I would return the SAFC and the e-manage and get a real EMS for starters. I would recommend either a Hydra Nemesis or a AEM as they both ofter plug and play solutions. Then, buy some HKS 264 cams and you should be very close to your goal. That turbo is a TERRIFIC turbo for the 3S but it may have difficulty reaching 350 on pump gas. I would imagine that you will be in the 320-340 range with cams on a good tune (not a crappy black box tune) which will be more than you will ever need in FWD street car - trust me.
post Dec 14, 2005 - 12:31 PM
nik
Joined Sep 30, '02
QUOTE(jgreening @ Dec 14, 2005 - 11:15 AM) [snapback]367098[/snapback]
i would agree go stand alone
post Dec 14, 2005 - 12:37 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
I agree 100% about the stand alone.
A Wolfkatz fuel rail would be a good investment.
I'd recommend at least 700cc injectors.
This post has been edited by WannabeGT4: Dec 14, 2005 - 12:53 PM
post Dec 14, 2005 - 1:16 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
well the way i see it your damn close to 350 fwhp as i see it now, 18 psi on a gt32 you should put out 350fwhp. you will be pushing the safety of your motor though.
max horsepower on a gt32 is 420hp.
the the e-manage ultimate support partial throttle tuning?
also i see no need for you to go full standalone, unless your going to be fully tunning the ign, theres nothing the e-manage cannot do, unless it dosnt do partial tunning.
but if youve got 2grand laying around i would, get a 5s block, build it, and slap the 3s head on it.
This post has been edited by recneps: Dec 14, 2005 - 1:21 PM
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Dec 14, 2005 - 1:21 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
just saw that this is a st185, so AWD power loss, i was trying to figure out why your guys numbers were so low.
anyways i still stick with most of my statement. no need for cams or a larger turbo.
built 5s bottom end and done.
post Dec 14, 2005 - 2:03 PM
dans_st
Joined May 24, '03
From Andrews TX
recneps Posted Today, 12:21 PM
the engine is an ST185 RC engine the vehicle is a 94 ST.
recneps Posted Today, 12:16 PM
I spoke to greddy they said that the E-manage ULTIMATE does have full ignition tuning.
Also as far as going full standalone- I don't have the cash YET, the AEM EMS is around $1.8-2k and that is all I want to spend for right now.
Basically what I am doing is gathering all parts And new gaskets to have the engine ready, then getting axles and having a tranny built during spring after having the engine ready to go in
Then I am going to install the engine next summer, til then the E-manage ULTIMATE is going to run my 7AFTE, and then the 3SGTE after that, then later I will get a standalone when I have enough cash
So can I even reach the power figures I want on the E-manageULTIMATE+what I have +$2k ?
I know doing 264 cams($???)
fuel rail($???)
RC 750cc injectors($120)
What else can I do?
post Dec 14, 2005 - 2:34 PM
Akimbo
Joined Jun 30, '03
From O-town, FL
You can get yourself better brakes.
edit: and suspension. or someone will get hurt/die
This post has been edited by Akimbo: Dec 14, 2005 - 2:34 PM
- Ryan
aim: rkgreen04
post Dec 14, 2005 - 3:15 PM
just saw that this is a st185, so AWD power loss, i was trying to figure out why your guys numbers were so low. anyways
you do realize that it will only be FWD?
and that building a 5s bottom end WOULD BE POINTLESS
cause its already a FULL BOOST BUILT MOTOR
(really honestly where is your common sense?)
cams imo are a most needed piece inorder to reach 350 as well as the upgraded turbo which you seam to already have down....
you could run the greddy ultimate i think you should be fine but as with always you can only "trick" so much and the standalone will benefit you more (i can see your only using it as a temp so its not that big)
cam gears along with the cams would be a good idea, maybe even consider valves and springs as well
i'm not sure on the 750cc injectors cause you'd have to do the math..instead of just jumping on a random number so i'd defenitly suggest the research into this and grab the appropriate size for your setup
you might even want to checkout KO RACING street brawler kit as well
post Dec 14, 2005 - 3:38 PM
scothaniel
Joined May 1, '03
From Michigan
350 Wheel or 350 Crank HP?
Either way, 350 is getting close to the limits of the stock pistons. I think 350 crank is obtainable on 550's and a raising rate regulator with the stock fuel rail. Just elminate the banjo's and you'll have plenty of flow.
No need for anything bigger then 3" for the exhaust.
Water injection would be a good option, though I dont know how water & NOS would play together.
I was on route to 400HP at the wheels with a stock (3rd gen) motor, with just forged pistons, IC, 20G kit and Link EMS.
Scott
West Michigan
post Dec 14, 2005 - 3:46 PM
im kind of confused here.... whats that mod list? is it stuff you have, or stuff you want to buy for the 2k budget? why do you have a 35shot of nitrous listed? did you already buy a 3sgte, or is that part of your budget too ?
post Dec 14, 2005 - 4:22 PM
"ITS GT32 turbo
3.5" downpipe
HKS 65mm BOV flange
KOYO Radiator
magna flow exhaust
HKS filter
HKS catch-can
MSD Blaster SS coil
TRD short shifter
all that is what he has IN HAND
the turbo manifold he needs to buy
and i believe its 2000 after motor
post Dec 14, 2005 - 4:48 PM
Negative
Joined Apr 28, '04
From Houston, Texas
[/quote]
Really honestly where's your research? A built 5S bottom end will greatly increase hp. It's been proven and works great. There is a place here in Houston that speciallizes in stroked 5S/3S motors and he has built many 500HP+ motors from this combo.
Do your research before you flame someone else's great idea.
post Dec 14, 2005 - 5:04 PM
did you read his monitary requirements?
post Dec 14, 2005 - 6:26 PM
dans_st
Joined May 24, '03
From Andrews TX
lagos Posted Today, 02:46 PM
the mod list is what I already have in the car I also already have a new GT32(thanks PLAYR158), I already ordered the E-manage ULTIMATE yesterday, I am going to pick up the 3SGTE in January it is at a relatives house right now but I can't get off of work.
My basic budget right now is $2000 NOT including the turbo manifold or E-manage
Other things NOT included are:
Power Enterprise timing belt
race engineering head gasket
Water pump and all gaskets were replaced by previous owner before purchase
And as for my $2000 so far I am looking into doing
264 cams
fuel rail
RC 750cc injectors(maybe Larger if needed)
What else can I do?
post Dec 14, 2005 - 7:08 PM
buy an mr2turbo lsd tranny
Lo-Fi Version Time is now: February 19th, 2025 - 9:55 PM
