Enthusiast ![]() Joined Dec 11, '05 From MN, Rochester Currently Offline Reputation: 1 (100%) ![]() |
I had to put my 94 Celica in the garage more then a year ago. The clutch burned out and the CV boots were bad. Since then Ive been buying tools and reading for the last year about engine swaps. Well I was out last weekend doing some prep work to get the old engine ready to be pulled. I noticed on the old engine that there was oil coming out of the valve cover. I got some pictures. I just want to know if anyone here could tell me what the problem is and how I can prevent this from happing on my new engine.
This first picture shows oil all over down by the Oil filter. The second picture shows the valve cover the oil isn't coming out that bad from here. The last picture shows the right side of the valve cover and you can see the layer of oil. Thanks for any help |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) ![]() |
Valve cover. It's easy quicker fix. I changed mine a while back.
I just read what else you typed. You already seem to know it's your valve cover, now you just have to replace the gasket. Get the one with the rings around the plugs too. If that's gone bad, those rings will have gone bad too. Might want to check your gasket that seals the cam too, the one next to the timing belt. This post has been edited by Bigmeanbulldog55: Dec 14, 2005 - 11:51 PM -------------------- Live Free, Be Happy
Thanks thats all I needed to know.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
ur dizzy seal seems to have gone bad too.
Check to make sure that the oil filter is not leaking oil as well, u might need a new seal for the oil filter fittings inside of the engine. |
I have one more question its kind of weird but when I put in a new Air filter. I found sun flower seeds in the black box thats holds the air filter. Anyone else find sunflower seeds in the air filter? and Thanks for the help I will check out the oil filter to make sure its not leaking.
QUOTE(ToysRfast @ Dec 15, 2005 - 5:26 PM) [snapback]367700[/snapback] I have one more question its kind of weird but when I put in a new Air filter. I found sun flower seeds in the black box thats holds the air filter. Anyone else find sunflower seeds in the air filter? and Thanks for the help I will check out the oil filter to make sure its not leaking. lol...clean that **** out. just means that your car some how sucked them up and the filter did its job by not letting them go into the egnine. -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
QUOTE(ToysRfast @ Dec 15, 2005 - 5:26 PM) [snapback]367700[/snapback] I have one more question its kind of weird but when I put in a new Air filter. I found sun flower seeds in the black box thats holds the air filter. Anyone else find sunflower seeds in the air filter? and Thanks for the help I will check out the oil filter to make sure its not leaking. you driving through the corn fields again!? i found sand in mine, bout it. -------------------- ![]() |
I can't wait to see what I find next. So far Crazy oil leaks ,Sunflower seeds, lady bugs, really big Grass hoppers, and a wing from a bird well it looks like a wing from a bird.
Lo-Fi Version | Time is now: February 17th, 2025 - 4:31 PM |
