2 Pages V  < 1 2
> Miss shifting, kinda, Whats rong with me
post Dec 16, 2005 - 7:06 AM
QUOTE(playr158 @ Dec 16, 2005 - 2:17 AM) [snapback]367883[/snapback]
wow ummm i'm not goin to even respond to the kind of idiocracy of that last post....
dan, your "elietist" additude is getting REALLY old.
stop.
just to remind you,
you, or anyone on the site for that matter, is no better than the next guy.
so stop acting like you know it all, cause we all know in reality, you know very little.
post Dec 16, 2005 - 10:54 AM
no i understand his concept.....but its totally the opposite of the entire discussion....and i do understand "cassette' style swaps and i've raced motorcycles so i've played with plenty of gearing as well as building my own motors....
but my bad for the use of "idiocracy" i should have said "opposite thought posting".......the entire topic of the post here is to LOWER the RPM in 5th gear...maybe even fourth gear....to me when people talk about lowering and someone comes along and talks raising...while the concept is still good and dandy....its good for people who don't do trips, don't cruise on highways....which again goes the opposite of discussion.....
so really if you want to get back onto track and cut the crap....
lowering the 5th gear down and 4th gear....corey if you get time check it...if not...then oh well smile.gif
and just for some referances of proper changes in gear ratios and costing you can check out this thread here
http://forums.vwvortex.com/zerothread?id=2246118
This post has been edited by playr158: Dec 16, 2005 - 11:07 AM
post Dec 16, 2005 - 6:16 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Dan, I might run up just to check out their shop and the work they do, and I'll definately see how much such a thing would run us financially. But I know that a "bulletproof" tranny like they build would be nice when I swap....plus taller gears would benefit everyone. wink.gif
I'll keep everyone posted.
post Dec 16, 2005 - 6:25 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
heheh... you guys need to calm down a bit.
Also... there are two ways to modify the tranny. Changing the actual gears and then changing the final drive.
post Dec 16, 2005 - 7:11 PM
anubis0108
Joined Jun 6, '05
From Texas/Hawaii
QUOTE(Silver94CelicaOwner @ Dec 15, 2005 - 7:29 PM) [snapback]367769[/snapback]
Alright, some of you have probably heard of this place, but I just remembered of a place i heard about called Level 10 Performance Transmission Systems (www.levelten.com). But at any rate, they seem to do just such work specializing in Imports...and turns out its only a 20 minute drive from my house...lol.
Art, youre probably right about spending alot of money on an already well designed transmission for stock Celicas, however getting a good condition E153 tranny from a 10+ year old MR2 is getting tougher and tougher for higher horsepower applications like a motor swap. Level 10 does group buys, and it would be great to see if they could give a respectable deal on a cryotreated or "bulletproof" gear set for our S54's, and maybe a longer 5th gear for those who want a better cruising gear for their stock Celicas. Maybe over my christmas break I'll stop by their shop and see what they think. smile.gif
Anybody else interested??
you sparked my interest yea over chirstmas break if ya find out more info i want to know the pricing range.
I gotz 2 things my celi and a dream, the prob is commin up with the thrid one...
post Dec 17, 2005 - 4:19 AM
Celicav
From Virginia
Hey, not that you want one, but just drive an Auto and you will have much lower RPMs cruising in higher gears. I know this is "off topic", but just a thought.
post Dec 18, 2005 - 10:57 PM
Silver94CelicaOw...
Joined Oct 13, '02
Yeah, the auto tranny on the GT uses a much broader top gear since theres only 4 gears instead of 5. I figure that aside from having high RPMS at not-so-fast highway speeds in 5th, it would be nice to see what they could do for our S54 trannys in terms of strengthening them a little via cryotreating them or shotpeening, or whatever along with maybe a lower final drive ratio or lower final gears for better cruising.
In all, I think it would be helpful to look into.....think of all the MR2 and Celica owners that could benefit something like this. Plus, a buddy of mine wants to upgrade the torque converter on his WRX, so I have a good excuse to go up there anyway. wink.gif
I'll let you guys know how it goes.
This post has been edited by Silver94CelicaOwner: Dec 18, 2005 - 10:58 PM
post Dec 18, 2005 - 11:07 PM
[Freemantle]
Joined Jul 25, '05
QUOTE(RocketScott @ Dec 15, 2005 - 8:08 PM) [snapback]367784[/snapback]
QUOTE(playr158 @ Dec 15, 2005 - 11:20 AM) [snapback]367608[/snapback]
i'd like a 5th gear conversion on my celica just to drop the rpms about a grand and save some gas
Maximum fuel efficiency occurs at peak horsepower.
Erm, yes, that's true. Kinda. Your torque peak is at your vE peak, the engine speed at which the combustion chamber can successfully burn the most fuel. As far as efficiency goes, that would be the least efficent part of the powerband, as your fuel burned/engine cycle ratio is at its highest. Your most efficent engine speed is idling in neutral biggrin.gif.
Oh, and for the "custom transmission" discussion: Honda people (88-91 CRXs for this example) have been using the short ass ZC transmission with an SI 5th gear for quite some time, and it is cheap-as-free. The 1-4 ZC transmission allows you to tear up to 70 mph while staying well within your powerband. The SI final drive/ 5th gear allow real power to be made at 115mph and 140mph top speeds.
This post has been edited by [Freemantle]: Dec 18, 2005 - 11:11 PM
1995 Celica ST - Riceball grocery getter. I saved her from Neons, 19" rims and TVs. All-stock save a weld-on muffler (does that count?) and V-AFC.
1991 CRX - The hobby car. I say that because I can never seem to get it completely together!
post Dec 19, 2005 - 3:51 AM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
' date='Dec 18, 2005 - 8:07 PM' post='368762']
You don't go anywhere sitting in idle. What would be the point of rating engines like that? I'm refering to fuel burned/miles driven, not fuel burned/engine cycle. Sometimes I oversimplify or omit important stuff, my bad.
You right about peak torque coinciding with the brake mean effective pressure. The volumetric efficiency doesn't necessarily coincide with peak torque though and it's certainly not the speed at which the combustion chamber can burn the most fuel. It's simply a ratio of charge volume to cylinder volume, no mention of how well that charge burns. There are many more factors involved like combustion efficiency.
I think at this point we've moved well off topic and beyond most of the people on this site in terms of usefullness. Just to stay on topic: I think I'll stick with my stock transmission
post Dec 19, 2005 - 4:17 AM
macavely
Joined Nov 4, '02
QUOTE(creis @ Dec 15, 2005 - 2:01 AM) [snapback]367465[/snapback]
I've had my car for going on 2 years and yet I cant stop doing this, almost every time I hop on the freeway I accelarate at a rather fast pase 3rd, 4th, 5th and once I get to about 3k in 5th (60-65mph) I pull it out of 5th and try and drop it into 6th I catch myself before I slam into reverse spin out and flip off the road but still why. it makes no sence to me that I always go for a 6th gear when I know I dont have one. Is it me or does the 5sfe tranny gear ratio feel like it should have a 6th gear?
anyone else have a problem with this, and does anyone know of a swapable tranny that has a 6th gear, I know the salara trany bults up, but I thnk its just another 5spd.
yea i have done that before.... i also have totally missed 3rd and shifted into 5th from 2nd and also into 1st from 4th .. and wow .. not a nice feeling or sound... i also still stall around corners sometims... droping for 3rd to 2nd ... at low speeds.. still trying to figure out how i still do that.... but the worst is when R jams ... and i have to pull back to N then back into R....
as for tranny that bults up .. yeah .. the one you have.. the simplist thing to do would be going to a tranny shop having them pull your internal ... and giving you a custom 6th gear... but that comes at a high price... but if you have the funds and are willing to do that.. i can give you the names/numbers of some tranny shop that can help you with that ..
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 9:46 PM
