> full rebuild and upgrade
post Dec 22, 2005 - 1:52 PM
ok here is a list of parts and pieces i have so far that i'm goin to replace and/or upgrade and who makes it
Coilover Sys.----------TEIN
EDFC-------------------TEIN
SwayBar F&R----------Susp. Tech.
Pillowball, Front-------Cusco
Pillowball, Rear--------Cusco
Brake pads Rear------EBC
6gc RR caliper---------Bendix
6gc RL caliper---------Bendix
6gc R rotor------------SP Perform.
7gc big brake(Front)----------ROTORA
Wheels-------------------------STERN (ST2)
Tires Front---------------------BFGOODRICH------------KDW2 215/35YR18
Tires Rear---------------------BFGOODRICH------------KDW2 245/35YR18
Axel Left-----------------------CROWN
Axel Right---------------------CROWN
so basically what i'm asking is....
what would you add/change/remove to/from this list
and WHY would you do so......
if you can't say WHY i don't want a post....lookin for some good reasons and so forth
(oh BTW i don't need strut bars wink.gif )
This post has been edited by playr158: Dec 29, 2005 - 1:58 AM
post Dec 22, 2005 - 4:40 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
why would you need to replace your axles? what kind of 400+ hp motor u putting in there?
post Dec 22, 2005 - 4:41 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
how good are the pillowball mounts? what are they supposed to do?
post Dec 22, 2005 - 4:49 PM
purplegt4
Joined Feb 7, '03
adjust camber
post Dec 22, 2005 - 4:52 PM
cusco upper pillow ball mounts are not only stronger and pretty but they allow camber adjustment.....
post Dec 22, 2005 - 7:33 PM
nik
Joined Sep 30, '02
QUOTE(playr158 @ Dec 22, 2005 - 3:52 PM) [snapback]370138[/snapback]
how did you brake 2 of them even when i was turboed and did 1/4 at spokane speed way i never had a problem with my stock axels
and thats a nice list of parts there about $4000
post Dec 22, 2005 - 9:49 PM
more then 4000$
and the driver side inner CV boot was broken just because it did....
post Dec 23, 2005 - 2:56 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
What Stern's are you looking at? Since most of their wheels are 8.5" or wider, and meant for RWD applications
**** Photobucket
post Dec 23, 2005 - 6:39 PM
Cutrara
Joined May 6, '05
From PA
Why do you need a big brake kit, unless you're producing massive amounts of power or autocrossing? If you're just looking for better handling I'd go with:
Rear Disc conversion
Cross drilled/slotted rotors all around
Some type of high performance pads
Stainless Steel Braided Brake lines
I can understand how the 7GC big brake kit could be a nice addition, but to me, not worth the some $1200 it costs.
post Dec 24, 2005 - 1:18 AM
unless you seen an autocrosser running 18" chrome rims i think your goin on the wrong track wink.gif
and i already have wats on your list minus the SS brake lines but good idea i'll add them to the list...
big brakes are for the fact that they are big brakes and freakin sweet....
honestly do dinky lil ST rotors look good behind massive 18s? nope.... i need sumthing to fill the space
post Dec 24, 2005 - 1:34 AM
http://photobucket.com/albums/y174/srplayr...w¤t=JC2077.jpg
stock 6gc front brakes with 18s..............
7th gen AEM big brakes with 18s............
http://memimage.cardomain.net/member_image...9/473030_32.jpg
post Dec 24, 2005 - 10:03 AM
Cutrara
Joined May 6, '05
From PA
First pic doesn't work, but damn, they do look sweet in that second pic. Can't wait to see it finished, it will be badass.
post Dec 26, 2005 - 1:08 AM
macavely
Joined Nov 4, '02
while your at it dan .. replace all your suspension bushings ... your sturt monut tops .. get the adjustable ones...
post Dec 26, 2005 - 11:50 AM
mac read the list....
cusco upper pillowball mounts
adjustable in the front
post Dec 28, 2005 - 8:26 PM
SHERMAN
Joined Dec 22, '05
From STL
Does Tein even offer a electronic damping force controller that works with their SS coilovers for the Celica?
7a-fte in progress
still need a manifold, fuel pump, greddy e-manage, and oil lines / water lines
post Dec 28, 2005 - 11:59 PM
Cutrara
Joined May 6, '05
From PA
QUOTE(SHERMAN @ Dec 28, 2005 - 8:26 PM) [snapback]372226[/snapback]
I think theres some problems with hood clearence, you need to use the GT-FOUR hood, because it gives some extra room under the hood for the controllers.
post Dec 29, 2005 - 12:31 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Dan, I think 95CelicaST is right....Sterns start at 8.5" wide, so just consider that when you shop. I love Stern wheels too, but thats alot of rotating mass unless performance and fitment is a secondary concern.
post Dec 29, 2005 - 1:53 AM
yea my fronts are 8.5" wide and the rears are 9.5" wide
and fitment well thats wat offset is for....that and nothing a little bodywork couldn't help if needed
QUOTE(Cutrara @ Dec 28, 2005 - 11:59 PM) [snapback]372325[/snapback]
oh you have to use the ST185 EDFC system and need a hood change/cut to allow for the extra height of the EDFC
post Dec 29, 2005 - 3:17 AM
purplegt4
Joined Feb 7, '03
QUOTE(playr158 @ Dec 29, 2005 - 1:53 AM) [snapback]372376[/snapback]
do i know u?
post Dec 29, 2005 - 2:59 PM
Silver94CelicaOw...
Joined Oct 13, '02
performance haha thats joke
Uh oh, Dan.....I have a feeling thats how your last project got into trouble. "....nothing a little bodywork can't help....." kindasad.gif
9.5" wide wheels are going to rub like mad, I can't see them fitting withough hitting the inside of the strut on bumps or griding against the wheelwell. I mean, not to rain on the parade here....it'll look great with deepdish wheels like that, but I think the drivability of your car will suck hardcore if you use such a wide wheel. wink.gif
Lo-Fi Version Time is now: November 30th, 2024 - 5:27 AM
