> LED Question, voltage
post Dec 23, 2005 - 12:10 PM
djultimate
Joined Dec 1, '05
From South Windsor, CT
I have some 4 volt LED's that I wanna install inside my climate control unit. Will I still need to use a resistor if I hook 3 of them in series, since the total voltage would be 12 volts? Trying to find the easiest way to do this.
post Dec 23, 2005 - 12:18 PM
Cutrara
Joined May 6, '05
From PA
It depends on what the specs are on them, I have a bunch of LEDs that can handle between ~2.4-3.5 volts. So I always run them in series of 4.
Edit: I reread your post, if they can take 4 volts, you don't need a resistor, but remember, car electrical voltage fluctuates, It can get down to 10 volts, *I think* before it won't start, and can be as high as 13+ if the car is running with no load on the alternator.
This post has been edited by Cutrara: Dec 23, 2005 - 12:20 PM
post Dec 24, 2005 - 1:49 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
my celicas alternator spikes way up at 14v when i messured from the dome light socket. but the climate control stayed damn near 12v, in both battery and altenator.
Lo-Fi Version Time is now: December 3rd, 2024 - 9:46 AM
