![]() Enthusiast ![]() ![]() ![]() Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) ![]() |
Hi all!
I think that I have mess up. My Mechanic have a Gen 1 4AGE 20v Silver top with upgraded 264 cams with VVT He stated to me that he still have vvt. VVT is in this case is either on or off. VVT-i is variable VVT. Now if what he stated to me is true(which I do not have any doubt), that means that you may not lose vvt-i if you have upgrade your cams Maikl! His cams was purchase for the 20v. I do not know if there are from Todaracing or TRD, by there cam from Miami. I will try and see how the VVT setup works in this case tomorrow. Just did some research, and it may seem right now that toda offer cams for VVT system. In fact, with further research, VVT and VVT-i is in the VVT controller. But here is where the problem can arise. Qoute from Bill Sherwood (http://www.billzilla.org/vvtvtec.htm):- "The early VVT system was relatively simple, ie, at a specific rpm (~4400rpm on the 20 valve 4AGE's) the computer signals the OCV to open, this lets oil pressure go through a special gallery in the #1 inlet cam bearing, through the centre of the inlet cam to the VVT pulley. There's a small piston in the VVT pulley, and once it gets enough pressure behind it, it starts to move outwards, causing the outer part of the pulley to turn in relation to the inner part, due to the helical spline that guides the piston's fore & aft movement." So if you purchase a cam not design for vvt, good bye vvt, but if you buy a cam enable vvt, you are in luck So Maikl, there may be some hope for you. Looking at todaracing, you can get cams with vvt. My mistake was that once you go to a big cam, you would want to dial in the HP and torque for you driving habits or where there just occurs at their max. If you use a Cam Gear, you will lose vvt, vvt-i. So maikl, http://www.todaracing.com/products/toyota/..._3sg_specs.html 264 would be good for you. Idle a little rough This post has been edited by west_minist: May 18, 2003 - 9:00 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 3, '03 From cyprus Currently Offline Reputation: 0 (0%) ![]() |
so what you areb telling me is if i order the 264 camshaft will fit my car? are you sure men? oh by the way my brother has a corolla with the 4age 20v black top
Yes.
That good. Has he modify it let? Let me know when he does ![]() Ok, here is our project. We have modify the silver top 20v to very close to 200HP w/ 264 cams with vvti, trd header, polish head and other little stuff. Our new plans is for a black top. are :- New polish head, 8.0 or 8.3 low compression pistons, 264 cams from the silver top, new TB, and turbo. and other stuff. The head is all that we are waiting on. We have the silver top bottom. The silver top was turbocharge with normal cams and head. behave like a beast. So, when ever your brother starts, let me know. This post has been edited by west_minist: May 18, 2003 - 8:37 PM |
no my brother is not the biggest fan of speed the only thing he has on his car is some 15s rims and suspension but its very beautifull is the 1998 model and its silver and it is fast as it is! now as for me do you thing the toda cams will fit my car with out any proplem?
Yes.
As I keep in telling you, contact toda racing for the best cam you want. ![]() 264 idles slight rough. This is base on the 4age 20v 264 cams. Maikl, you must do some reading. It will help you alot. This post has been edited by west_minist: May 18, 2003 - 8:37 PM |
i had a levin before i got my ss-iii i had the black top engine with an air filter an exhaust and iridium sparks, it was white with 16s it was realy beautiful! now as for me doing my reading i belive that i know enought about engines but i dont uynderstand english very well and i do not know how to write my oppinions down anyway the guy who brings the toda in cyprus told me that there are no cams for my car made by toda this is why i asked you if you are sure, if you say you are sure i will order them tomorow because i trust you know better
Ok. I have been stress out the last couple of weeks at work.
He is right. I am very sorry. (Unconsciously, I knew the statement below would work when I told you so. I had always knew and did not think twice when I lose my VVT-i upgrading to bigger cams) You can use the 3SGTE Cams since the 3SGE gen 4 head is the same in the cam profile as the 3 gen 3SGTE. Even it you lose the vvt-i, it is ok since you will be running big cams to over come that effect. I will contact toda racing on your behalf and post the email here. Is that alright? You see, at the end of the day, you are modding to the 3SGTE specs. There is no strenght differents in the blocks of the 3rd gen 3SGTE and the 4 Gen 3SGE. http://www.toysport.com/ENGINE%20EVOLUTION...0THE%203SGE.htm http://www.toysport.com/3sgt_tech_notes.htm Did you check out that site. In the usa, there are really specialise there. Toda racing is a Japanese company. There make racing parts for all the well know cars. Alot of 3SGTE builds ups come from the 3SGE which is contrary to manu USAer believes. It is may be easier to get the a 3SGTE block, but it can be started from the 3SGE block, install some oil coilers in the head (maybe present in the latest gen 3SGE, 11.5:1) since the 4AGE 20v have them.) http://www.todaracing.com If you need help with the english, you have all of us here. I have msn and AIM. Again, I wll try and see what toda can do for you. Look here! A 3sge is a 3sge. Available for: 4AG, 4AG (5 valve), 3SG, 7MG TODA Racing offers a complete valve train package for the 4AG, 3SG, and 7MG. These kits are recommend when using high lift, long duration camshafts. They will prevent engine damage and power loss due to valve float. Engine Price Comment 4AG $880 Complete Kit 4AG $220 AE101 (5 valve engine) Valve springs only 4AG $220 AE111 (5 valve engine) Valve springs only 4AG $120 Valve Springs Only 3SG $900 Complete Kit Available for: 4AG, 3SG, 3SGT, 1ZZ, 2ZZ (4AG Flywheel shown) TODA Racing lightweight flywheels increase throttle response and aide in overall vehicle performance. These are not modified stock flywheels, but brand new units produced from 100% chromoly steel. In addition to these flywheels, TODA Racing also offers high performance clutch packages which include a TODA flywheel, pressure plate, and disk. Please contact us for pricing on clutch kits. Engine Weight Price Comment AE86 4AG ~ 4/1987 3.7 kg $450 Fits Corolla and AW11 MR2 AE92 4AG ~ 4/1989 3.7 kg $450 AE92 4AG 5/1989 ~ Up 4.4 kg $450 AE101 4AG 4.4 kg $450 SW20 3SG 4.5 kg $450 SW20T 3SGT 4.5 kg $450 Toyota 3SGT Camshaft Specifications Price :$370 (For cams up 9.8mm lift); $490 (for cams with more than 9.9mm lift) Part # Duration Lift (mm) 3SG-SW001 256 8.5 3SG-SW002 256 9.0 3SG-SW011 264 8.5 3SG-SW012 264 9.0 3SG-SW013 264 10.3 3SG-SW021 272 8.5 3SG-SW022 272 9.0 3SG-SW023 272 10.3 3SG-SW031 280 10.3 3SG-SW041 288 8.5 3SG-SW042 288 9.0 3SG-SW043 288 10.0 3SG-SW044 288 10.5 3SG-SW051 304 8.5 3SG-SW052 304 9.0 3SG-SW053 304 10.5 3SG-SW061 310 10.5 3SG-SW071 320 10.8 3SGTE 98-99 86.0 86.0 1998 9.0 260 6000 CALDINA ST215 3SGTE III 96-97 86.0 86.0 1998 8.5 255 6000 CELICA GT4 C. ALLTRAC ST205 3SGTE II 98-99 86.0 86.0 1998 8.5 245 6000 MR2 MR2 SW20 3SGTE I 92-93 86.0 86.0 1998 8.8 225 6000 MR2 MR2 SW21 3SGE IV 99-00 86.0 86.0 1998 11.0 210 7600 ALTEZZA DVVTi 3SGE IV 98-99 86.0 86.0 1998 11.0 200 7000 CEL. SSIII ST202 3SGE IV 98-99 86.0 86.0 1998 11.0 180 6600 RAV4 SXA11   3SGE III 96-97 86.0 86.0 1998 10.3 170 6600 CARINA     3SGE II 92-93 86.0 86.0 1998 10.0 165 6800 CELICA   3SGE I 86-89 86.0 86.0 1998 10.0 145 6500 CELICA Engine Type Valv/Cyl Year Disp. BHP Torque Bore Stroke CR stock boost+other remarks /angle [*=JIS] [lb ft] [mm or inches] 3S-GE DOHC 4/50 95-98 1998 180@7000 142@4800 86 86 3S-GE DOHC+VVT-i 98- 1998 190@7000 152@6000 86 86 3S-GE DOHC+DualVVT-i 99 1998 200@7000 159@4800 86 86 11.5:1 JP Altezza (Auto5spd) 3S-GE DOHC+DualVVT-i 99 1998 210@7600 159@6400 86 86 11.5:1 JP Altezza (6spd) 3S-GTE DOHC 4/50 95-98 1998 255@6000 225@4000 86 86 (Celica GT-4 Japan) 3S-GTE DOHC 4/50 98 1998 260@6000 239@4400 86 86 (Caldina GT-T Japan This post has been edited by west_minist: May 18, 2003 - 8:37 PM |
thanks........... and do what ever you thing its ok with me i just want to get some more power to my engine and it seems that nobady gives a s..t here in cyprus about my car. thanks for the understanding
read my update at top again. I have to modify it for accuracy.
![]() I have sent them an email. So wait until I can get a very good comfirmation from them. This post has been edited by west_minist: May 18, 2003 - 9:37 AM |
oh and something i want your oppinon what about adjustable campulleys? i looked in the ling you told me but it says that i will lose the vvt-i if i use them so what do you thing? get only the cams? i am thinging getting them both and f..k the vvt-i the vvt-i is just for fuel economy nothing that will effect my hp anyway, tell me what cams to get and i will
Yes as I state to you. Once you are looking for serious power, you will lost it.
That is why I am having difficulty with you and others on low power. Check you the Supra and others. Yes. go for the cam gear from either HKS or Jun. I like them better than the toda. The cams will be the 3SGTE. It is up to you on the 264 or 272. If you are really planning to do some really head work, 272 maybe good. My mechanic have a 4age 20v w/ 264 that idle farily rough. THe stock ecu have problems with it. You have a aftermarket one, so it should not be a problem. Do you have aim? Please log on RC Engineering 550cc Injectors (enough head room over 240HP+[(actual 340hp+)] @ flywheel and for turbocharging later if you can. If not, use up to 420cc ) JUN GT Surge Tank (2015M-T001) JUN SPROCKET (1033M-T702) OR HKS Cam Gear (2204-RT001) JUN CAMSHAFT KIT (1033M-T005) JUN STROKER KIT (1029M-T003) (87.0x92.0mm) JUN Racing Valve Guide (1008M-T002) JUN ULTRA LIGHT WEIGHT Flywheel (2010M-T012) http://www.hksusa.com By phone: (310) 491 3300 - M thru F 8am-5pm PST By mail: HKS USA -13401 S. Main Street -Los Angeles, CA 90061 http://www.motec.com West Coast 5355 Industrial Drive Huntington Beach, CA 92649 Tel: (714) 897-6804 Fax: (714) 897-8782 info@motec.com East Coast 169-2 Gasoline Alley Mooresville, NC 28117 Tel: (704) 799-3800 Fax: (704) 799-3874 Jay Caldwell jay@motec.com http://www.autronic.com Phone International (61) 7 4051 6672 Fax International (61) 7 4051 3683 Phone 07 4051 6672 Fax 07 4051 3683 Email info@autronic.com http://www.junusa.com http://www.junauto.co.jp/index-e.html info@junauto.co.jp PHONE 81-3-3920-4165 FACSIMILE 81-3-3594-2689 http://www.kaazusa.com Newport Exotic Cars 935-A Sunset Drive Costa Mesa, California 92627 USA phone (949) 631-0990, fax (949) 631-0909 newportcars@kaazusa.com http://www.todaracing.com Official North American Distributor AKH Trading 192 Technology Drive, Suite V Irvine, CA 92618 USA Tel: 949-450-1056 Fax: 949-450-1059 E-mail: toda@todaracing.com http://www.rceng.com 1728 Border Ave Torrance, CA. 90501 Phone (310) 320-2277 Fax (310) 782-1346 RC@RCEng.Com This post has been edited by west_minist: May 18, 2003 - 8:38 PM |
I have also contacted Jun on this matter.
Can you check out your cam profile for your engine again other 3sge including the the ST185 and the ST205 3SGTE? This info would help. Toda responded to me but I need more info from them. It seems that there offer cams for the old 3sge and as usual do not want to commit to the 94+ gen and up. Ok, here is email1:- "Thank you for your e-mail and interest in TODA Racing. Our 3SG parts are only for the older 3SG(T) engines. We don't offer any parts for the newer 3SG Celica engines. " The 3SG(T)= 3SGE & 3SGTE I have sent him what year up to that he offers. From what I have been reading, the heads are the same. The 98 Head came out with vvti and the Black top came with VVT-i on both cams. We just need to confirm if the cams have the same dimensions since we will not be using vvt. I have also ask him if we can return unsed parts. If you want, you can order a 264 and see how it looks. I am waiting on JUN since there are more up to date in there parts. Also, you can resell them on ebay if there do not match up properly. That would be a better bet If not just be patient. We want to do this right. If you go ahead, we can add this to 6gc for cams that work with the 3SGE 98+ Check out this Ivan Tighe Engineering Pty Ltd t/a Tighe Cams 225 Montague Rd West End Qld 4101 Australia A.B.N. 46 009 747 139 Tel (07) 3844 4283 Fax (07)38463662 Internet: www.tighecams.com.au Email: sales@tighecams.com.au I will email them now. This post has been edited by west_minist: May 18, 2003 - 8:56 PM |
Maikl!
Here is an update from toda. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> We offer the following Toyota 3SG camshafts: 3SG (ST162 Celica) 3SGT (SW20 MR2 turbo) 3SGE (Japanese market Toyota Alteza only) No other 3SG applications are offered by TODA >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 3SGE IV 99-00 86.0 86.0 1998 11.0 210 7600 ALTEZZA DVVTi 3S-GE DOHC+DualVVT-i 99 1998 200@7000 159@4800 86 86 11.5:1 JP Altezza (Auto5spd) 3S-GE DOHC+DualVVT-i 99 1998 210@7600 159@6400 86 86 11.5:1 JP Altezza (6spd) I think the red and black top Beams are the same head. There cam out the same year. I do not see toyota producing different heads for vvt-i and dual vvt-i. That mean that you should be able to get the cams for the Altezza to work in yours. Can you do some research on this and see how the Oil Control Valve for vvt-i fits the altezza so that you can add it to your engine for more perfomance? You do not have to. Again, if you are planning to use cam gears, vvti is dead. No word from JUN yet |
thanks again you realy take this seriusly
I have not recieve any word from Jun yet.
You ask me to let you know what you can order. I am not liable for damage to your engine and not abl to return parts that purchase. If you want, you can resell stuff through ebay. Call Toda Racing and Jun (contacts above) and explain to them that you need:- AN Intake 264 cam and an 264 Exhaust cam for the Altezza. You would also need (but not) 2 cam gears. If the intake is VVT-i enable which there did not dispute, then you will have vvt-i on the intake. This post has been edited by west_minist: May 19, 2003 - 2:04 PM |
Hi Maikl!
Still no word from JUN. I sent them an Email one last time about the same matter. Any word from Jun down your side? |
no nothining yet.............. not from toda either
Ok. |
Any update Maikl?
nop nothing yet about the engine but i've got my new rims today
Lo-Fi Version | Time is now: February 17th, 2025 - 10:41 PM |
