> Ok got a stalling problem, And then it won't start...
post Dec 26, 2005 - 7:59 PM
gamesteristj
Joined Feb 18, '04
From Spokane Washington
Ok my celi was out of commision for about a week, about a 2 weeks ago. The problem I thought and it fixed it untill now was the distributer was bad. But its hapening again. But if I let the car sit for a while 2+ hours it will start and run fine for about 15 min then it starts to studder and die if it is just idleing. So if you gat any ideas I am going to get rid of it.
Another thing If i got a big dent due to a hit and run, right in front of my rear wheel well would that total it. Cause I caught the guy!!!!
TJ
post Dec 27, 2005 - 9:58 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
check your AIC, spray some intake cleaner in your intake and clean it. carb cleaner in your air valve control. check your o2 sensors.
post Dec 27, 2005 - 2:22 PM
immortal
Joined Aug 21, '05
From Cyprus
i have the same problem and i think i have a bad air flow sensor..
LewFX can you please tell me where to spray the cleaner? This may solve my problem?
post Dec 27, 2005 - 2:53 PM
LewFX
Joined Jan 28, '05
take it off, spray inside the valve. disconnect the hoses and a few nuts and bolts, unscrew the screws and should come off, if you need a pdf, check celicatech bgb's
Lo-Fi Version Time is now: November 24th, 2024 - 3:32 AM
